AP One Flex
This product is out of stock.
Recommended Alternatives
MU – MIMO
MU-MIMO offers significantly increased efficiency to your network. Now multiple client devices can receive data simultaneously through AP One Flex MU-MIMO and beamforming antenna technology, which concentrates and steers radio signals towards specific client devices.
Simultaneous Dual Band
Reduce Wi-Fi congestion and interference. Simultaneous dual-band Wi-Fi on the AP One Flex gives you two independent networks that work together, so all of your devices can connect without clashing.
Waterproof Enclosure
Provide Wave 2 ac Wi-Fi in more places with Flex. The tough IP55 rated enclosure is perfect for outdoor environments as well as other dusty and moist locations.
Boost your Network
Increase your wireless speeds with AP One Flex. Connect your devices with Wave 2 11ac while enjoying enterprise-grade reliability
3-Port Switch
Connect to all of your devices, wired and wireless. Hooking up cameras, video surveillance, and even another AP One Flex is a breeze thanks to a built-in GE port and a PoE input.
User Access Control
Control network access with separate logins for each user group. AP One access points support up to 16 SSIDs, each with independent bandwidth limits and web blocking.
MIMO Directional Antenna
Forget about outboard antennas. The Flex has MIMO directional antennas built right in.
Centralized Management
Configure AP One Flex onsite or from the cloud. Peplink AP Controller lets you locally manage access points from your Balance router, while InControl 2 offers a complete cloud-based solution accessible from any web-browser.
Social Wi-Fi Hotspot
Guests can now access your Wi-Fi hotspot with their Facebook login. In exchange, you can learn more about your customer base with insightful reports
Complete Network Solution
Enjoy better network integration and performance. AP One access points are a perfect complement to Balance routers, together providing blazing speed and superior reliability across your entire network.
#PowerofPeplink
