The Pepxim Smart Reader and Time and Attendance System make attendance management into a more than easy process. Employees can easily clock in and out using their NFC cards, while management gains access to an intuitive yet powerful system that provides real-time visibility and significantly reduces administrative workload.
Security. Broad Card Compatibility
Smart reader is compatible with today’s most secure card platforms including several HID iClass and Proxy formats.
Flexible Deployment Options
Traditional systems require local servers and controllers. Deploy Smart Reader across multiple buildings, remote offices, and other mobile locations
Expandable Cloud Platform
TA Cloud allows you to integrate reader data seamlessly into your existing access control or attendance system.
Admin View
User View
With the TA system, employees can access information about their daily attendance, as well as the status of pending leave requests. With employees able to look up their own attendance information, they no longer need to make inquiries to HR, saving administrative overhead.
Attendance Management
The TA System is accessible from anybrowser. Employees are able to see their attendance record and leave balance. They can also request time record adjustments as needed.
Self Service Leave Requests
Save administrative costs by having employees perform their own leave requests. Once the request has been submitted, all it takes is one click from the manager to have it take effect.
Time and Attendance Mobile App
Review attendance information on-the-go with our mobile app, available for iOS and Android.
Products
![Employee Attendance Management System & Software #8](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Employee-Attendance-Management-System-Software-8-1.png/w=992)
Smart Reader
Reads NFC cards and uploads attendance information to the Time and Attendance System where it can be reviewed via reports and used to calculate payroll.
![Employee Attendance Management System & Software #9](https://imagedelivery.net/ELltIDciDa6C0z-Ffk6NgQ/www.peplink.com/2020/05/Employee-Attendance-Management-System-Software-9.png/w=992)
MAX HD Series
The Smart Reader can be powered by PoE supplied by MAX cellular routers.
This combination is ideal for vehicular deployments. Receive location information for passengers as they board; useful for big data analytics.
