Use Cases
Railway Deployments
Transportation
Events & Temporary Connectivity
Dual Cellular and Redundant SIM Slots
Dual Cellular and Redundant SIM slots allow you to use the same or different cellular providers for bandwidth bonding, data overage protection or eliminating blind spots.
Compact and Powerful
The MAX HD2 mini’s compact metal enclosure (1.6 x 5.0 x 5.8 inches), gives you a tough and powerful mobile connectivity solution.
Terminal Block for Secure Power Supply
The MAX HD2 Mini is equipped with a terminal block for secure power installation in vehicles and other locations.
PoE Output Option Available
Cut down on cabling and simplify deployments. With an optional PoE activation kit purchase, the MAX HD2 Mini supports 802.3at PoE output, so one cable is all you need for both connectivity and power.
Meets Strict Security Compliance
Got a strict no-Wi-Fi security policy? Built without Wi-Fi, the MAX HD2 Mini is a great choice for deployments with compliance requirements.
Certified Toughness
In addition to rugged metal enclosure, the MAX HD2 mini is certified on:
Shock and vibration resistance
(EN 61373:1999 IEC 61373:1999)
RF Port Lightning Immunity
(ITU-T K.20 (+/- 1.5 kV))
Railway Applications
(EN 50155)
Electromagnetic Compatibility
(EN 61000)
Fleet Tracking and Management
With built-in GPS fleet tracking and InControl 2 cloud-based management, you can keep tabs on location and manage your mobile network from any Internet-connected device. InControl 2 is our cloud based device management, monitoring, and reporting tool designed specifically for Peplink and Pepwave devices.
Customizable Captive Portal
Branding your captive portal is as easy as uploading your logo and terms & conditions. You can easily set bandwidth allowance and access duration per user or manage access using RADIUS server.
With Social Wi-Fi Hotspot support, you can also receive valuable demographic data from your users.
