Use Cases
Broadcasting
Telemedicine
Disaster Recovery
Public Safety & First Responders
Compatible With:
Sample Topology, Disaster Recovery
In a disaster, reliable connectivity is a must for first responders, aid workers & everyone affected
- SpeedFusion creates an unbreakable and bonded connection using multiple 4G LTE/3G modems from different carriers.
- In case of a WAN failure, SpeedFusion instantly and seamlessly switches traffic to another connection; for always-on mobile networking.
- Multipurpose wireless applications, including video surveillance, VoIP communication, emergency Wi-Fi are possible in disaster recovery projects.
Quad Embedded Cellular Modems
Quad Cellular Modems and Redundant SIM slots allow you to use up to four different cellular providers for bandwidth bonding, data overage protection or eliminating blind spots.
Terminal Block for Secure Power Supply
The MAX HD4 is equipped with a terminal block for secure installation in vehicles and other locations.
8-Port GE Switch and Optional PoE Output
Cut down on cabling and simplify deployments. With a PoE activation kit purchase, the HD4 supports 802.3at PoE Output, so one cable is all you need for both connectivity and power.
Certified Toughness
In addition to rugged metal enclosure, the MAX HD4 is certified on:
Shock and vibration resistance
(EN 61373:1999 IEC 61373:1999)
Railway Applications
(EN 50155)
Electromagnetic Compatibility
(EN 61000)
FirstNet Ready & ESN Certified
FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The HD4 supports band 14, providing additional coverage as the situation demands.
MAX HD4 wireless routers are also certified by UK’s Emergency Services Network (ESN). The routers are now approved for use in the country’s fleet of first responders and emergency services vehicles.
Fleet Tracking and Management
With built-in GPS fleet tracking and InControl 2 cloud-based management, you can keep tabs on location and manage your mobile network from any Internet-connected device. InControl 2 is our cloud based device management, monitoring, and reporting tool designed specifically for Peplink and Pepwave devices.
Customizable Captive Portal
Branding your captive portal is as easy as uploading your logo and terms & conditions. You can easily set bandwidth allowance and access duration per user or manage access using RADIUS server.
With Social Wi-Fi Hotspot support, you can also receive valuable demographic data from your users.
#PowerofPeplink
WAN Link Health Check
Bandwidth Allowance Monitor
USB 3G/4G LTE Modem Support
IPv6 Support
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
Weighted
Enforced
Persistence
Priority
Overflow
Least Used
Lowest Latency
Fastest Response Time
Global Positioning System ntegrated GPS
Device Location Map
Location Tracking Data
GPS eXchange Format (GPX)
Up to Seven Days
Complete VPN Solution SpeedFusion VPN/SpeedFusion Hot Failover/SpeedFusion Bandwidth Bonding
Site-to-Site VPN
Bandwidth Aggregation
Hot Failover
256-bit AES Encryption
Pre-shared Key Authentication
Dynamic Routing
X.509 Certificate Support
PPTP/L2TP/OpenVPN Server
Local User, LDAP, RADIUS, Active Directory Authentication
IPsec VPN (Network-to-Network) 7
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
VRRP HA support
Security Stateful Firewall
DoS Prevention
Web Blocking
Advanced QoS User Groups
Bandwidth Reservation
Individual Bandwidth Limit
Application Prioritization
By User Groups
SIP, HTTPS, VPN QoS
Custom Application QoS
AP Controller AP Controller Support
Wi-Fi Usage Statistics
Captive Portal Support Support for Wired and Wireless LAN Clients
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
Package Content MAX HD4
12V4A Power Supply (ACW-635)
4x Dual Band Wi-Fi Antennas (ACW-341)
1x GPS Active Antenna (ACW-232)
8x 2dBi 4G LTE Antennas (ACW-813)
1 Pair of Mounting Brackets (ACW-731)
Product Code Description ACW-618 Includes 2x 56V/2.1A Power Supply
Enables 8x 802.3at/af PoE Output Ports (PoE License automatically applied after kit purchase)
ACW-622 Includes 1x 56V Power Supply
Enables 4x 802.3at/af PoE Output Ports (PoE License automatically applied after kit purchase)
MAX-HD-020-SPF Activates 20 SpeedFusion VPN/SpeedFusion Peers MAX-HD4-LC-5WAN WAN Port Activation License for MAX HD4. Convert LAN ports 1-3 to WAN ports 3-5. FIPS-LC-HD4 FIPS License for HD4 ECP-MAX-HD4-LTEA-1Y EssentialCare+ (1-Year) for MAX HD4 LTEA ECP-MAX-HD4-LTEA-2Y EssentialCare+ (2-Year) for MAX HD4 LTEA ECP-MAX-HD4-LTEA-4Y EssentialCare+ (4-Year) for MAX HD4 LTEA SVL-464 1-Year EssentialCare for MAX HD4 LTEA SVL-527 2-Year EssentialCare for MAX HD4 LTEA ANT-MB-42G-S-W-6 7-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White) ANT-MB-42G-S-B-6 7-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black) ANT-MB-40G-S-W-6 5-in-1 Cellular Antenna System with GPS Receiver (White) ANT-MB-40G-S-B-6 5-in-1 Cellular Antenna System with GPS Receiver (Black) ANT-MB-02-R-W-6 2×2 MIMO Wi-Fi Dual Band Antenna (White) ANT-MB-02-R-B-6 2×2 MIMO Wi-Fi Dual Band Antenna (Black) LIC-VWAN Activate 1x Virtual WAN LIC-2VWAN Activate 2x Virtual WAN LIC-3VWAN Activate 3x Virtual WAN -
Product Code Carrier Embedded Modem 4G Bands 3G Bands MAX-HD4-LTE-E-T Europe /
International /
CAT-4
4 4G LTE:
B1, B3, B5, B7, B8, B20, B38 (TDD), B40(TDD), B41 (TDD)
WCDMA/HSPA+/DC-HSPA+: B1, B5, B8 MAX-HD4-LTEA-W-T Worldwide /
CAT-6
4 4G LTE-A:
B1, B2, B3, B4, B5, B7, B8 , B12, B13, B20, B25, B26, B29, B30, B41
2500WCDMA/HSPA+/DC-HSPA+:
B1, B2, B3, B4, B5, B8
MAX-HD4-LTEA-P-T Asia Pacific /
CAT-6
4 4G LTE-A:
B1, B3, B5, B7, B8, B18, B19, B21, B28, B38, B39, B40, B41
B1,B5, B8, B9, B19
UMTS: B6
TD-SCDMA: B39
MAX-HD4-LTEA-WF-T America / FirstNet /
CAT-12 / CAT-6
4 Cellular 1:
4G LTE-A Pro:
B1, B2, B3, B4, B5, B7, B8, B9, B12, B13, B14, B18, B19, B20, B26, B29, B30, B32, B41, B42, B43, B46, B48, B66
Cellular 2-4:
4G LTE-A:
Cellular 1:
HSPA+: B1, B2, B4, B5, B6, B8, B9, B19
Cellular 2-4:
WCDMA/HSPA+/DC-HSPA+: B1, B2, B3, B4, B5, B8
MAX-HD4-LTEA-WK-T Global* /
CAT-12 / CAT-6
4 Cellular 1:
4G LTE-A Pro:
B1, B2, B3, B4, B5, B7, B8, B9, B12, B13, B18, B19, B20, B26, B28, B29, B30, B32, B41, B42, B43, B46, B48, B66
Cellular 2-4:
4G LTE-A:
Cellular 1:
Cellular 2-4:
- MAX HD4
- 1x 12V4.2A Power supply with power cord (ACW-635)
- 4x Wi-Fi Dual Band Antennas (ACW-341)
- 1x GPS Antenna (ACW-232)
- 4x LTE Antennas (ACW-813)
- 1 Pair of Mounting Brackets (ACW-513)
Case Studies
- Tutoring Camp Project
- River Cruise Internet
- Making the Jump to Unbreakable Live Broadcast
- Broadcasting the Bangsaen 42 Chonburi Marathon
- Connecting a Drillship to Her Headquarter Using LTE
- Rapidly Deploy Reliable Communications for Healthcare in Trying Times
- RTL Berlin, Germany
- Anderlecht Bus Coach Wi-Fi, Belgium
- Singapore National Day Parade, 2015
- Greenville County Sheriff’s Office, US
- Dawlish Railway, UK
- Super Yachts Deployments with Peplink
- Real Time Hitman SD-WAN, UK
- LSU Health Mobile Mammography, USA
- Bowen Engineering, USA
- Multi-Site Infrastructure in the Food Industry
