Use Cases
LTE for CCTV
Maritime
Industrial Deployments
Directional or Omni Antennas
The BR1 IP55’s built-in Directional and Omni-directional Wi-Fi antennas, which are software selectable. So, it’s easy to optimize antenna performance at any time.
Built-in PoE and 3-Port Switch
The BR1 IP55 includes built-in PoE input and a 3-port LAN switch to reduce clutter and the need for extra equipment. 802.3at PoE+ output is optional add-on, so one wire is all you need for both connectivity and power you can share with security cameras and other devices.
Embedded 802.11ac Wi-Fi
The MAX BR1 IP-55 comes equipped with integrated 802.11ac Wi-Fi AP.
Waterproof IP55 Enclosure
Deploy the BR1 IP55 router with confidence in harsh indoor and outdoor environments. Its waterproof IP55 enclosure stands up to dust, vibration, and inclement weather, making it a great choice for industrial, emergency, and other heavy-duty applications.
There is More
We specialize in making complicated technologies simple. Achieve what others cannot with the following
