Portable 4G LTE Connectivity
The MAX BR1 Slim gives you full-featured mobile connectivity in a package that measures just 1.1 x 3.8 x 4.8 inches. Its rugged metal enclosure stands up to moisture, dust, and vibration. It gives you and your devices, such as surveillance camera, LTE connectivity anywhere.
Use Cases
In-Vehicle Deployments
Real Time Video Streaming
Public Safety
Redundant SIM Slots for Multiple Carriers
Redundant SIM slots with automatic switching for reliable network. You can also set the MAX BR1 Slim to automatically switch SIM cards when you’re in danger of exceeding a data cap. It also allows you to travel across the borders without changing SIM cards manually.
Dual Micro USB Power Input
Connect one of the two built-in 5V micro USB ports to a 10000mAh power bank for up to 7 hours of operation. Running low on power? Connect a second power bank before disconnecting the first for uninterrupted networking.
Terminal Block for Secure Power Supply
The MAX BR1 Slim is equipped with a terminal block for secure power installation in vehicles and other locations.
There is More
We specialize in making complicated technologies simple. Achieve what others cannot with the following.
