MAX HD2 & HD4 with MediaFast
Unbreakable Connectivity with Content Caching
The HD2 MediaFast and HD4 MediaFast team up embedded cellular modems and other great features of the HD Series with our MediaFast content caching, which lets you store content for later playback anywhere, regardless of connectivity.
300Mbps400Mbps Content Caching Cellular Modems MAX HD2 HD4 #2
Works With
  • iTunes
  • iOS Updates
  • TED.com
Combine the bandwidth of several mobile connections to form an ultra-fast data link. Sustain bandwidth-hungry and latency sensitive tasks without the need for fixed lines.
With the help of WAN smoothing network traffic will be assigned to WAN connection with the lowest latency. Use multiple WAN connections to create a single, jitter-free data streem.
UK’s Pluss demonstrates unbreakable VoIP with SpeedFusion
300Mbps400Mbps Content Caching Cellular Modems MAX HD2 HD4 #4
Dual/Quad Embedded Cellular Modems
The HD2 with MediaFast includes two built-in 4G LTE modems (four on the HD4 with Mediafast). It allows you to use the same or different cellular providers for bandwidth bonding, data overage protection or eliminating blind spots.
Terminal Block for Secure Power Supply
MAX HD2 with MediaFast is equipped with a terminal block for secure installation in vehicles and other locations.
PoE Output Option Available
Cut down on cabling and simplify deployments. With a PoE activation kit purchase, the HD2 with Mediafast supports 802.3at PoE, so one wire is all you need for both connectivity and power.
200Mbps Content Cashing Router MediaFast 200 #8
Complete Solution & Centralized Management
The MAX HD2/ HD4 are supported by InControl 2, Peplinks Cloud-Based SD-WAN Network Management Platform, which lets you provision, monitor, and manage your routers. With built-in GPS fleet tracking you can keep tabs on location and manage your mobile network from any Internet-connected device. All from a single screen.
  • Product CodeHD2-MFA-LTE HD4-MFA-LTE
    WAN Interface2x Embedded LTE Modems with Redundant SIM Slots 1x USB Interface 2x GE4x Embedded LTE Modems with Redundant SIM Slots 1x USB Interface 2x GE
    LAN Interface8 (GE)8 (GE)
    Wi-Fi Interface802.11ac/a/b/g/n 1166Mbps 2×2 MIMO Wi-Fi WAN and/or AP Simultaneous Dual-Band AP802.11ac/a/b/g/n 1166Mbps 2×2 MIMO Wi-Fi WAN and/or AP Simultaneous Dual-Band AP
    Cache Throughput150Mbps150Mbps
    Cache Storage120GB SSD120GB SSD
    Video and Content CachingYesYes
    Router Throughput 1400Mbps400Mbps
    Recommended Users 2150500
    LTE ModemDownlink/Uplink Datarate: 100Mbps/50MbpsDownlink/Uplink Datarate: 100Mbps/50Mbps
    LTE-A ModemDownlink/Uplink Datarate: 300Mbps/50MbpsDownlink/Uplink Datarate: 300Mbps/50Mbps
    SpeedFusion VPNYesYes
    SpeedFusion Hot FailoverYesYes
    SpeedFusion WAN SmoothingYesYes
    SpeedFusion Bandwidth BondingYesYes
    Number of SpeedFusion VPN SpeedFusion Peers2/20 +2/20 +
    Cellular Antenna Connectors4x SMA Antenna Connectors 8x SMA Antenna Connectors
    GPS and Wi-Fi Antenna Connector2x SMA GPS Antenna Connector 4x Dual Band Wi-Fi Antennas 2x SMA GPS Antenna Connector 4x Dual Band Wi-Fi Antennas
    Power InputDC Jack/Terminal Block: 12V – 56V, 4ADC Jack/Terminal Block: 12V – 56V, 4A
    Power OutputUp to Eight 802.3at PoE Outputs*Up to Eight 802.3at PoE Outputs*
    Power Consumption38W (Max. Before PoE Output)38W (Max. Before PoE Output)
    Dimensions1.9 x 11.5 x 6.9 inches | 50 x 292 x 177 mm1.9 x 11.5 x 6.9 inches | 50 x 292 x 177 mm
    Weight4.20 pounds | 1.9 kg4.20 pounds | 1.9 kg
    Operating Temperature-40° – 149°F  |  -40° – 65°C-40° – 149°F  |  -40° – 65°C
    Humidity15% – 95% (non-condensing)15% – 95% (non-condensing)
    CertificationsFCC, CE, RoHS, E-Mark, IC
    EN 61373:1999 IEC 61373:1999 : Shock and Vibration Resistance:
    EN 50155: Railway Applications
    EN 61000: Electromagnetic Compatibility
    Warranty1-Year Limited Warranty1-Year Limited Warranty
  • WANWAN Support for PPPoE
    Static IP
    DHCP WAN Link Health Check
    Bandwidth Allowance Monitor
    USB 4G LTE/3G Modem Support
    Support for Dynamic DNS
    Services IPv6 Support
    Extended DHCP Options
    DHCP Reservation
    DNS Proxy for LAN Clients
    DNSBuilt-in Authoritative DNS
    Support for A, CNAME, NS, MX, PTR, SOA, SRV, TXT Records
    QoSUser Groups
    Individual Bandwidth Limit
    Application Prioritization
    By User Groups
    SIP, HTTPS, VPN QoS
    Custom Application QoS
    Content CachingVideo Caching
    iTunes
    iTunes U
    TED.com
    Content Caching
    HTML
    JavaScript
    Flash Applications
    AP ControllerSupport for Pepwave AP Series
    Auto AP Discovery
    Auto AP Firmware Management
    AP Profile Configuration
    Wi-Fi usage statistics
    Command Line Interface
    InControl Cloud Management
    Router Utility Mobile App
    Email Notification
    Active Client & Session Lists
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
    Complete VPN SolutionSpeedFusion VPN/ SpeedFusion
    Site-to-Site VPN
    Bandwidth Aggregation
    Intelligent Failover
    256-bit AES Encryption
    Pre-shared Key Authentication
    Dynamic Routing
    PPTP VPN Server
    RADIUS, LDAP Authentication
    Security Stateful Firewall
    DoS Prevention
    Web Filtering Blacklist
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    WINS Server
  • Product CodeDescription
    ACW-618Includes 2x 56V/2.1A Power Supply
    Enables 802.3at/af PoE Output Ports (PoE License automatically applied after kit purchase)
    ACW-622Includes 1x 56V/2.1A Power Supply
    MAX-HD-020-SPFSupports up to 20 SpeedFusion VPN/SpeedFusion Peers
    MAX-HD4-LC-5WANWAN Port Activation License for MAX HD4. Convert LAN ports 1-3 to WAN ports 3-5.
    • MAX HD2 with MediaFast
        • 12V4.2A Power Supply
        • 4x 5dBi Wi-Fi Antennas
        • 1x GPS Active Antenna
        • 4x 2dBi 4G LTE Antennas (4G LTE)
        • 1 Pair of Mounting Brackets
    • MAX HD4 with MediaFast
        • 4x Dual Band Wi-Fi Antennas
        • 8x 2dBi 4G LTE Antennas
  • Product CodeCarrierEmbedded Modems4G Bands3G Bands
    MAX-HD2-MFA-LTE-E-TEurope/International24G LTE:
    B1, B3, B5, B7, B8, B20, B38 (TDD), B40(TDD), B41 (TDD)
    WCDMA/HSPA+/DC-HSPA+: B1, B5, B8
    MAX-HD4-MFA-LTE-E-TEurope/International44G LTE:
    MAX-HD2-MFA-LTEA-W-TAmericas/Europe24G LTE-A:
    B1, B2, B3, B4, B5, B7, B8 , B12, B13, B20, B25, B26, B29, B30, B41
    2500WCDMA/HSPA+/DC-HSPA+: B1,B2, B3, B4, B5, B8
    MAX-HD2-MFA-LTEA-P-TAsia Pacific24G LTE-A:
    B1, B3, B5, B7, B8, B18, B19, B21, B28, B38, B39, B40, B41
    WCDMA/HSPA+/DC-HSPA+: B1,B5, B8, B9, B19
    UMTS: B6
    TD-SCDMA: B39
    MAX-HD4-MFA-LTEA-W-TAmericas/Europe44G LTE-A:
    B1, B2, B3, B4, B5, B7, B8, B12, B13, B20, B25, B26, B29, B30, B41
    MAX-HD4-MFA-LTEA-P-TAsia Pacific44G LTE-A:
    UMTS: B6
    TD-SCDMA: B39
