Works With
iTunes
iOS Updates
TED.com
Hassle Free Solution for Branch Connectivity
Stable Connectivity
Peplink routers enable you to add bandwidth, wired or wireless, anytime and load balance multiple Internet links. Automatic failover allows you to maintain an unbreakable connection. You can download media-rich course materials effortlessly with the MediaFast.
Prefetch Off-Peak Downloads
Schedule one-time or recurring content downloads during off-peak hours, and then playback downloaded content anytime. Need HD video and other content in places with spotty or congested Internet connections? Download whenever and wherever the connection is best. Then pack up and take the MediaFast anywhere you need seamless content delivery
Reporting.
Deep Insights.
On-Demand.
Check bandwidth usage and savings. Track popular URLs and file types. Monitor client IP addresses, find your heaviest users, and more, all from a single intuitive interface.
Cache.
Download x1.
Playback x∞.
Cache iTunes/iTunes U and other content automatically by domain and file type. With MediaFast, you can download once and play back over and over again, cutting loading time, bandwidth usage and cost. Keep content as long as you like or purge it automatically by file type and age.
Complete Solution & Centralized Management
MFA 200 is supported by InControl 2, Peplinks Cloud-Based SD-WAN Network Management Platform, which lets you provision, monitor, and manage your routers. All from a single screen.
