Antennas
Accessories
Antenna MAX
Combining high-performance antennas with a rugged enclosure, the Antenna MAX extends your router’s capabilities and allows you to take it outdoors.
Enjoy your router’s full potential without the compromise of cable loss.
Outdoor Cellular Antennas
Peplink Antenna Application Brochure
More Possibilities Than You Can Imagine
Discover different scenarios where you can benefit from our antennas,
not just what’s implied by their names.
Indoor Cellular Antennas
ACW-205
Indoor 3G Antenna
Product Code: ACW-205
2dBi Gain | SMA Connectors
ACW-234
Indoor LTE/5G Wideband Cellular Antenna
Product Code: ACW-234
Compatible with all Peplink Cellular Routers
ACW-235
Indoor LTE/5G very Wideband Cellular Antenna
Product Code: ACW-235
6GHz Cellular Antenna
ACW-409
1.5m Magnetic Cellular Antenna Base
– 1.5m Magnetic Cellular Antenna Base
– SMA male to SMA female (base)
Product Code: ACW-409
ACW-801
3dBi Indoor Magnetic Cellular Antenna
Requires 1 unit per 3G modem
Product Code: ACW-801
3dBi Gain | SMA Connectors
ACW-808
Ultra-Wideband Indoor Magnetic Cellular Antenna
Requires 1 unit per 3G modem, 2 units per LTE modem
Product Code: ACW-808
ACW-813
Indoor Cellular Antenna. (704-960MHz/1575MHz:1dBi; 1710-2170MHz: 3dBi; 2300-2690MHz: 2dBi)
Product Code: ACW-813
3dBi Peak Gain | SMA Connectors
ACW-815
Indoor LTE Cellular Antenna
Indoor Cellular Antenna. (698-960MHz: 2.1dBi; 1710-2170MHz: 2.5dBi)
Product Code: ACW-815
2.5dBi Peak Gain | SMA connector
Outdoor Wi-Fi Antennas
ACW-202
Fiberglass Outdoor Wi-Fi Omni Antenna (N-Male)
Product Code: ACW-202
2.4Ghz | 8dBi Gain
ACW-308
Product Code: ACW-308
5.8Ghz | 8dBi Gain
Indoor Wi-Fi Antennas
ACW-221
Magnetic Base Wi-Fi Indoor Omni Antenna (RP-SMA)
Product Code: ACW-221
2.4Ghz | 5dBi Gain
ACW-304
Indoor Wi-Fi Omni Antenna (RP-SMA)
Product Code: ACW-304
2.4Ghz | 5dBi Gain
ACW-340
Dual-Band Indoor Wi-Fi Omni Antenna in White (RP-SMA)
Product Code: ACW-340
5GHz & 5dBi | 2.4GHz & 2.5dBi
ACW-341
Dual-Band Indoor Wi-Fi Omni Antenna in Black (RP-SMA)
Product Code: ACW-341
GPS Antennas
ACW-232
Magnetic GPS Antenna
Product Code: ACW-232
SMA Connectors
Industrial Networking Accessories
POTS Adapter
Convert your hard-to-maintain Plain Old Telephone System to cost-effective VoLTE infrastructure.
Peplink 4-Pin to USB-C Power Cable (ACW-791)
Power Your Routers with Ease.
SIM Injector
More SIM, More Range.
MAX Adapter
State of the Art Cellular Modem.
Extension Cables
UV Stabilized and Low-loss Extension Coaxial Cables.
PoE & Power Supply
Need an Additional PoE, Power Supply, Power Cord or Power Adapter? Check What We Have to Offer!
Mounting Kits
Rack Mount & Ear Mount Accessories Compatible with Peplink Devices.
Premium Deck Mounts
Premium grade mounts to withstand any weather condition at sea.
Cables & Adapters
Install Your Wireless Deployments Faster with Dedicated Cables and Adapters.
