Starlink with Peplink
Supercharge Your Starlink Experience
As a Starlink Authorized Technology Provider, Peplink provides robust networking solutions for the most challenging business environments, whether that’s providing reliable Internet for the corner store point-of-sale terminal, or connecting 5,000 passengers on a globally sailing cruise liner.
By combining Peplink and Starlink solutions, problems concerning Internet costs, speeds and reliability are now possible to be solved in even the most daunting of physical conditions.
Find an
Authorized Peplink & Starlink Solution Provider
Authorized Peplink & Starlink Solution Providers (ASPs) are premier organizations that receive specialized training and support on Peplink and Starlink business solutions, and can help solve your Internet access challenges. Our full list of ASPs can be found below.
We also work closely with the following Starlink Authorized Resellers who are also Peplink Partners:
Blue Wireless (SG, MY, AU, US, UK, EU) , Hypha (AU, NZ) and Venn Telecom (BE, EU)
Interested in becoming an Authorized Solution Provider?
What are the benefits of using both Peplink and Starlink?
Backup terrestrial with satellite
Automatically backup your fiber, wired or cellular Internet connection with Starlink.
Use multiple Starlinks in the same network
Connect and share multiple Starlinks together for increased reliability.
Easily manage all devices on the same platform
Control both Peplink and Starlink equipments from InControl, our browser-based remote management platform.
Router features made specifically for Starlink
Working closely with Starlink engineers, our devices contain features made specifically for use with Starlink’s network.
Common Scenarios
Maritime
RV
5G
Scalable
Unbreakable Connectivity
• Focus: Failover from Starlink to SIM
Ensure seamless connectivity and session persistence with zero downtime.
With Hot Failover, users will be able to fallback to a standard cellular connection when Starlink gets cut off.
Optimize Your Network
• Focus: Traffic Steering
Take full control of what traffic travels through Starlink and your other WANs.
During peak hours, designate priority traffic through other WANs so ongoing applications don’t suffer.
Likewise, designate high bandwidth, low priority traffic (e.g. file downloads) through Starlink during off-peak hours to take full advantage of their data plan.
Bonding with Starlink
• Focus: Bond multiple Starlink connections
Combine multiple Starlinks for extra redundancy and create a solid network with unbreakable connectivity.
Useful for providing reliable connections where nothing else works (e.g. Cruises / Remote events)
• Focus: Bond Starlink with LTE/Ethernet solutions
Combine the bandwidth of Starlink connections with LTE to provide seamless connectivity in remote area.
Useful for providing full time connectivity suited for areas where connectivity has been unreliable (e.g. Mobile / Maritime deployments).
Supercharged Starlink Integration
*Available with Firmware 8.4.0 and above
• Focus: Stow/Unstow from InControl’s UI
Priority 1 (Highest)
Priority 2
Control your Starlink Antenna from Peplink’s UI and synchronize multiple antennas all at the same time.
Instead of relying on Starlink’s router to stow/unstow your antenna, you can do it with the click of a button from InControl.
• Focus: Updated “Least Used” Outbound Policy
Prioritize WANs with the most available uplink.
This new outbound policy requested directly from Starlink means more efficient usage of multi-WAN networks that include Starlink.
Starlink Applications
Fixed Site RV / Land Mobility Maritime
Target Users
Retail Chain
Office
Remote Location
RVers
Marine Engineering
Yachts
Boaters
Business Challenges
Downtime equals loss
Heavy duty network traffic
Network security
Unreliable access to the internet in rural areas
Interruptions while on the move
Extreme weather conditions
Unstable network connections
Heavy duty operations
Use Cases
Video Conferencing
VoIP
VPNs
POS
Large User Bulk Internet
Video Conferencing
VPNs
Small User Internet
Gaming & Streaming
VPNs
VoIP
Guest Wi-Fi
Remote Control of Bulky Equipment
Large User Base
Benefits
Failover without dropped calls or conferences
SLA grade uptime when combining multiple 5G or other broadband links
Zero touch provisioning with private hosting options
Secure remote management of RDP, SSH, Serial, Telnet, HTTP/S devices
Band Locking helps connect you to your preferable bands
Improve network speed & latency
Hot Failover allows seamless connectivity while on the go
Overcome stability issues in maritime applications
Rugged enclosures to withstand extreme environments
Multiple WANs for Bandwidth Bonding
Suggested Products
BR1 Mini HW3
B One 5G
BR1 Pro 5G
Balance 310 5G
SDX Pro
BR1 Mini HW3
BR1 Pro 5G
Transit Duo Pro
BR1 Pro 5G
BR2 Pro
MAX HD4 5G
EPX
What’s More
Webinar
User Testimonials
Configuring
Case Studies
FAQ | Resources
A. Yes, you can even continue using the Starlink app to check your signal. We keep our firmware up to date to stay current with Starlink updates.
A. Starlink roams across many satellites over the course of a single day. These roams may cause problems for applications like Zoom, Teams, and other real time video/audio streams. At worst, it may even cause full internet outages.
Peplink's SpeedFusion lets you combine Starlink with 5G, 4G, and other WANs to seamlessly fill in those gaps so your applications remain smooth and reliable.
You can customize your application priorities and protection so you can keep costs in check and make sure important traffic is protected.
A. Firmware 8.3.0 introduces improvements to our dynamic weighted bonding algorithm while bonding multiple Starlink antennas together for greater upload and download speeds.
We plan on continuing our work on improving the ability to combine the speed of Starlink with the reliability of terrestrial broadband and 5G/4G connections. When using Starlink with these connections, Hot failover and WAN Smoothing are recommended. Achieving increased upload and download throughput across Starlink and other WANs is expected to have mixed results. Further improvements with these connection types are likely possible with the fine tuning of network settings, as well as with firmware improvements targeted for future releases.
A. No, we do not restrict configurations or continued operation of your network devices if your subscription expires. We will always allow our users to log directly into their router and change any parameters they need, as well as perform manual firmware upgrades.
All of our devices come with a one year subscription of our care plans and InControl cloud management. Customers can choose to continue these subscriptions, but you will not be locked out of your network if you decide not to extend your subscriptions.
