Product Image
Model:
Buy Online
Antenna MAX
Maximum Flexibility, Maximum Gain
Outdoor Cellular / GPS Antenna + Enclosure
Maximum Gain: Up to 6.6dBi
Worried about cable loss?
Minimize cable loss by installing your router directly into the antenna enclosure.
Retain maximum signal gain by connecting the Antenna MAX to the rest of your network with an ethernet cable.
10m RF cable 5dB cable loss 10m RF cable 5dB cable loss
UV-resistant plastic enclosure
Maximum durability
UV-resistant plastic enclosure resists moisture, water intrusion, salt spray and corrosion
Maximum flexibility
Mix-and-match antenna with many routers including:
BR1 Mini Series
BR1 Mini Series*
BR1 Mini Series
Transit Duo Pro^
BR1 Mini Series
BR1 Pro 5G / CAT-20^
BR1 Mini Series
POTS Adapter^
AP One Rugged
*BR1 Mini series: BR1 Mini, BR1 Mini Core, BR1 Mini 5G, BR1 Mini M2M.
^For certain products which do not support PoE In, a PoE Splitter is required.
Multiple Mounting Options
Fixed-roof L-mount set included
Wall Mount
Wall Mount
Surface Mount
Surface Mount
Mounts easily on mobile equipment and vehicles – trucks, vans, boats.
Pole Mount
Pole Mount
Maximum value
Antenna MAX is a cost-effective way to get maximum performance from your cellular and 5G routers in outdoor environments
Photos
front of Antenna MAX back of Antenna MAX inside the Antenn MAX
  • Product CodeDescription
    ANT-MAX4xLTE/5G, 2x Wi-Fi, 1xGPS 600-6000MHz, IP67, SMA male (Cellular, GPS), RP-SMA male (Wi-Fi), White
    • 1x Antenna MAX
    • Double sided 3M adhesive pad
    • 3x Cable Gland
    • 1x L-Mount Set
    • 2x Hole Plug
