Product Image
Model:
Buy Online
Mobility 82G Cover
Mobility 82G
Mobility 82G Cover Layer
Built for 5G
Omni-directional 8×8 MIMO mobile antenna for the best performance.
Ultra Wide Bandwidth
Wide frequency range (600-6000MHz) supporting LTE and 5G connectivity in any location.
Robust Design
IP67 rated, low profile and durable housing.
Mobility 82G Robust Design
5G and Ultra Wide Bandwidth
Built for 5G
Robust Design
Mobility 82G Easy Installation
Easy Installation
Surface, panel installation for various applications.
Mobility 82G Flexible Applications
  • Public Safety & Mission Critical Connectivity
  • Mobile Healthcare
  • Transportation Connectivity
Actual Sizes
Mobility 82G Front Mobility 82G Top
  • Product CodeDescription
    ANT-MB-82G-S-W-68xLTE/5G, 2x Wi-Fi, 1xGPS 600-6000MHz, IP67, SMA (Cellular, GPS), RP-SMA (Wi-Fi), White, 6.5 ft / 2m
    ANT-MB-82G-S-B-68x LTE/5G, 2x Wi-Fi, 1xGPS 600-6000MHz, IP67, SMA (Cellular, GPS), RP-SMA (Wi-Fi), Black, 6.5ft / 2m
    ANT-MB-82G-Q-W-68xLTE/5G, 2x Wi-Fi, 1xGPS 600-6000MHz, IP67, QMA (Cellular, GPS), RP-SMA (Wi-Fi), White, 6.5 ft / 2m
    ACW-667Surface mount
    ACW-668Surface mount with magnets
    • 1x MB-82G
    • Long and short thread
    • Double sided 3M adhesive pad (Diameter: 15.2” / 386 mm)(Thickness: 0.08” / 2 mm)
