sim-injector-mini-header-pattern-background
sim-injector-mini-only-at-peplink-badge
SIM Injector sim-injector-mini-title-outline.svg
SIM Management from Afar.
sim-injector-mini-point-01-sim-cards.svg
Remotely manage up to 8x SIMs
Integrate up to 8 additional SIMs into your network without the need for physical intervention. Perfect for hard to reach deployments.
sim-injector-mini-point-02-poe.svg
One Ethernet cable is all you need
Power your device through PoE and forgo the need for a nearby power outlet. Power through Microfit Connector is also available for more flexibility.
sim-injector-mini-point-03-sim-injector-mini-top.svg
The best accessory we’ve ever made at only $499*
Durable, rugged, simple to use. At the affordable price of $499*, easy SIM management won’t be gated behind a paywall.
*Pricing applies to US region only, other regions may vary
Ports and Connections
  • Product SIM InjectorSIM Injector Mini
    SKUSIM-BK8-4E-56VSIM-MINI-8-1E
    SIM Slots8x Active SIM Slots, Mini-SIM (2FF)8x Active SIM Slots, Nano-SIM (4FF)
    LAN Interface4x 10/100/1000M Ethernet, PoE 802.3at Output Support*1x 10/100 Ethernet, PoE 802.3at Input Support
    Power InputDC Jack / Terminal Block: 12-56VDC Jack: 10-30V /
    802.3at PoE
    Dimensions5 x 5.8 x 1.6 inches /
    128 x 147 x 40 mm
    3.9 x 4.2 x 1.4 inches /
    100 x 107 x 35 mm
    Weight430 grams /
    0.94 pounds
    244 grams /
    0.54 pounds
    Operating Temperature-40° – 149°F /
    -40° – 65°C
    -40° – 149°F /
    -40° – 65°C
    Humidity15% – 95% (non-condensing)15% – 95% (non-condensing)
    Remarks* 56V DC input is needed for 4x LAN ports to have 802.3at
  • Product CodeDescription
    SIM-MINI-8-1ESIM Injector Mini
    SVL-SIM-MINI-1YEssectialCare (1-Year) for SIM Injector Mini
    SVL-SIM-MINI-2YEssectialCare (2-Year) for SIM Injector Mini
    ECP-C-1YEssentialCare+ C (1-Year)
    ECP-C-2YEssentialCare+ C (2-Year)
    ECP-C-4YEssentialCare+ C (4-Year)
    • 1x SIM Injector Mini
    • 1x 12V 2A 4 Pin Power Supply (ACW-632)
    • ^ Balance 20X, Balance 380X, and Balance 580X require FlexModule Mini for SIM Injector Mini support, while SDX, SDX Pro, and EPX require a compatible FlexModule Plus.
      * Please cross-check and confirm with the image below, the form factor of your FlexModule Plus.
      Supported FlexModule Plus
      Includes membrane marking ‘Cellular’
      SIM slot size 4FF
      Not Supported FlexModule Plus
      Includes membrane marking ‘Main’
      SIM slot size 2FF
