Manage Centrally, No Extra Hardware Needed
Each AP One AX comes equipped with InControl central management. View the health and data usage of your network from any web browser. Centrally manage your network’s SSID and radio settings from a single pane of glass. Use the searchable event log to quickly diagnose your entire network.
Turnkey or Custom Captive Portals
Customize your captive portal as little or as much as you would like. Right out of the box, it includes a captive portal ready for immediate use.
For a more branded user experience, you can edit every aspect of the captive portal using InControl.
Seamless Peplink SD-WAN Integration
The AP One AX works seamlessly with other services in the Peplink ecosystem, providing unique network capabilities, unmatched network flexibility and ease of use.
1. InControl Central Management
Monitor network health on a single dashboard. Push configuration proles on multiple devices at once. Remotely access the Web Admin of any device.
2. Balance/MAX/FusionHub
Provides unbreakable connectivity by
combining multiple WANs. Works with InControl to centralize VLAN, firewall, and outbound policy.
3. SD-Switch
Works with InControl to remotely configure and activate PoE ports. Monitor power consumption.
4. AP One
Works with InControl to centralize SSIDs, radio settings, and deliver captive portals.
Simply Better Wi-Fi
Wi-Fi 6: Faster, Better
This technology is 45% faster than Wi-Fi 5, has 4x more device capacity, and consumes less power for connected devices.
Enterprise-Grade Fast Roaming
This device supports 802.11k, v, and r, providing users with a more seamless roaming experience between access points.
