Enterprise-grade Wi-Fi for any environment. Set up customized captive portals and manage your Wi-Fi network with ease using InControl.
Common Features
Enterprise Wi-Fi Features
Customized Captive Portal
Detail Usage Monitoring via InControl 2
Zero Touch Provisioning
Access Point Series
SD Switch Series
SD Switch 8-Port Rugged
PoE Enabled Switch with 8 Gigabit Ports & 2 SFP Ports for Industrial Environments. Ready for any Environment.
SD Switch 16-Port Rugged
PoE Enabled Switch with 16 Gigabit Ports & 2 SFP Ports for Industrial Environments. Ready for any Environment.
SD Switch 24-Port Rugged
PoE Enabled Switch with 24 Gigabit Ports & 2 SFP Ports for Industrial Environments. Ready for any Environment.
SD Switch 24-Port Enterprise
PoE Enabled Switch with 24 Gigabit Ports & 2 SFP Ports for Enterprise Deployment.
SD Switch 48-Port Enterprise
PoE Enabled Switch with 48 Gigabit Ports & 4 SFP Ports for Enterprise Deployment.
