Connect From Afar
The Balance 20X (with FlexModule Mini LoRaWAN) can keep your sensor devices connected across long distances up to 10 miles within line of sight whether in remote locations, urban areas, or indoor environments.
Pay Less For More
Reduce costs on infrastructure, operations, and battery replacement. Sensor devices can achieve long battery life with the low-power optimized Balance 20X (with FlexModule Mini LoRaWAN). Requiring only minimal energy, its battery life can last up to 10 years.
Secure Your Connections
The Balance 20X (with FlexModule Mini LoRaWAN) utilizes the LoRaWAN network’s embedded end-to-end AES encryption. Application data is kept confidential, even to the network server, as it transports from end to end.
Deploy the Balance 20X with Flexibility
The Balance 20X (with FlexModule Mini LoRaWAN) has a capacity of up to eight channels and can support hundreds of thousands sensor devices. Maximize the license-free spectrum for IoT applications anywhere.
*Supports most common LoRaWAN gateway packet forwarding protocols such as Semtech UDP Packet Forwarder and Semtech LoRa Basics(tm) Station.
Locate in Real Time
Without the need for GPS, you can enable tracking applications that aren’t heavy on battery life and are low in cost.
Balance 20X
Product Code Embedded
Modem(s)Regions LTE Bands 3G Bands BPL-021X-LTEA-US-T-PRM 1x CAT-7 North America* B2, B4, B5, B7, B12, B13, B14, B25, B26, B41, B42, B43, B48, B66, B71 HSPA+: B2, B4, B5 BPL-021X-LTE-E-T-PRM 1x CAT-4 Europe/International B1, B3, B5, B7, B8, B20, B38, B40, B41 WCDMA/HSPA+/DC-HSPA+: B1, B5,
B8BPL-021X-LTE-US-T-PRM 1x CAT-4 North America^ B12, B14, B4, B2, B5, B13, B66, B71 B2, B4, B5 BPL-021X-LTE-MX-T-PRM 1x CAT-4 Latin America/Australia B1, B2, B3, B4, B5, B7, B8, B28, B40 WCDMA/HSPA+/DC-HSPA+: B1, B2,
B5, B8*US Carrier Certifications: AT&T, Verizon
^US Carrier Certifications: AT&T, T-Mobile, Verizon, US Cellular, FirstNet
Product Code Frequency Bands EXM-MINI-LORA-EU EU868, IN865, RU864 EXM-MINI-LORA US915, AU915, AS923, AS925, KR920 -
Product Code Description LIC-VWAN Activate 1x Virtual WAN on Balance 20X * LIC-2VWAN Activate 2x Virtual WAN on Balance 20X * LIC-3VWAN Activate 3x Virtual WAN on Balance 20X * PRM-A-1Y PrimeCare A (1-Year) PRM-A-2Y PrimeCare A (2-Year) PRM-A-4Y PrimeCare A (4-Year) PCP-A-1Y PrimeCare+ A (1-Year) PCP-A-2Y PrimeCare+ A (2-Year) PCP-A-4Y PrimeCare+ A (4-Year)
