Balance 30 Pro
Balance 30 Pro
This product is out of stock.
Recommended Alternatives
Balance 30 Pro
Unbreakable Branch Connectivity
The Balance 30 Pro comes equipped with two Ethernet WAN and one cellular WAN for automatic failover, making it an ideal choice for branch offices that absolutely must stay connected.
400Mbps Dual-WAN Router with LTE-A Balance 30 PRO #2
Peplink ‘s line of products includes features that make your enterprise deployment easier and increase your network reliability and security in several ways. Boost network data rates, reliability, and flexibility while slashing connectivity costs with Peplink SD-WAN technology designed for multi-WAN link load balancing. Use Load Balancing and SpeedFusion bandwidth bonding to deliver superfast VoIP, video streaming, and data using an SD-WAN enabled network.
  • Branch/Small Office
  • Small Business
  • Mid-Size Business
  • Large Enterprise/Campus
  • Cloud/VM
Use Cases
Retail
Hospitality
Branch Networking
Retail Connectivity Solution
The Balance 30 Pro can handle all your networking needs. With the PoE activation kit, its four PoE LAN ports can connect and power your payment terminal, IP phones, Wi-Fi hotspots. The Balance 30 Pro has one cellular and two Ethernet connections, ensuring that your network and business will keep running no matter what. Use the Ad Delivery service to deliver advertisements and surverys to your customers before they connect to your Wi-Fi.
400Mbps Dual-WAN Router with LTE-A Balance 30 PRO #4
Branch Site Setup
In this video Peter from West Networks demonstrates how to use the Balance 30 Pro to deploy branch office connectivity in under 5 minutes.
SD-WAN With Dual Wired Ports and LTE
The Balance 30 Pro supports two wired connections and one LTE with SD-WAN capabilities for traffic steering, load sharing and failover, powering your critical business continuity.
Redundant SIM Slots
Redundant SIM slots with automatic switching for reliable network. You can set the Balance 30 Pro to automatically switch SIM cards when you’re in danger of data overage, or aggregate capacity of multiple SIM data plans.
Add PoE Kit to Enable 4-port PoE Switch
With the PoE activation kit, all LAN ports can support PoE output. That way, you can hook PoE powered devices such as IP Phones and additional Wi-Fi APs. Perfect for Branch Networking.
Combine the bandwidth of several mobile connections to form an ultra-fast data link. Sustain bandwidth-hungry and latency sensitive tasks without the need for fixed lines.
400Mbps Dual-WAN Router with LTE-A Balance 30 PRO #6
Built to Last
Capable of years of uptime, the Balance  series easily handles monthly bandwidth that would crush lesser equipment. Every Peplink design is rigorously tested to exceed your expectations for speed, reliability, durability, and ease-of-use. We invest heavily in quality assurance and user experience testing to give you affordable, enterprise-class gear that just works, from the moment you take it out of the box.
Balance 30 Pro is supported by InControl, Peplinks Cloud-Based SD-WAN Network Management Platform, which lets you provision, monitor, and manage your routers. All from a single screen.
InControl makes your network scalable. From any web browser, you could remotely push a wide range of settings to multiple devices in your network
Captive Portal
QoS
400Mbps Dual-WAN Router with LTE-A Balance 30 PRO #7
Customizable Captive Portal With Ad Delivery
Use InControl to customize the captive portal and apply it to any SSID. With InControl’s scalable architecture, you can apply the SSID to multiple devices in your network using device tags. Use the cloud-based Ad Delivery Service (ADS) to monetize your Hotspot.
400Mbps Dual-WAN Router with LTE-A Balance 30 PRO #8
QoS : Determine Traffic Priority
QoS enables you to assign different priority levels to different types of traffic. Minimize latency by giving high priority to VoIP traffic. Control data costs by limiting the speed of bandwidth-intensive applications.
Web Admin Demo
#PowerofPeplink
    WAN Link Health Check
    - PING
    - DNS Lookup
    - HTTP
    Bandwidth Allowance Monitor
    USB 4G/3G Modem Support
    Intelligent Failover
    - changeip.com
    - dyndns.org
    - no-ip.org
    - tzo.com
    - DNS-O-Matic
    Extended DHCP Option
    DHCP Reservation
    DNS Proxy for LAN Clients
    VLAN on LAN Support
    Per-Service Load Distribution
    Multiple Algorithms
    - Weighted
    - Enforced
    - Persistence
    - Priority
    - Overflow
    - Least Used
    - Lowest Latency
    Complete VPN Solution- PepVPN
    - Site-to-Site VPN
    - Hot Failover
    - 256-bit AES Encryption
    - Pre-shared Key Authentication
    - Dynamic Routing
    - PPTP VPN Server
    - IPsec VPN (Network-to-Network)
    - X.509 Certificate Support
    Advanced QoS User Groups
    - Bandwidth Reservation
    - Individual Bandwidth Limit
    Application Prioritization
    - By User Groups
    - SIP, HTTPS, VPN QoS
    - Custom Application QoS
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    WINS Server
    VRRP HA Support
    BGP, OSPFv2 and RIPv2 Support
    SecurityDoS Prevention
    Stateful Firewall
    Support RADIUS Authentication
    Support LDAP Authentication
    Power RequirementsDC Jack: 10V – 56V
    CertificationsCE
    FCC
    RoHS
  • Product CodeCarrierEmbedded Modem 4G Bands 3G Bands
    BPL-031-LTEA-W-TWorldwide14G LTE-A:
    B1, B2, B3, B4, B5, B7, B8 , B12, B13, B20, B25, B26, B29, B30, B41
    WCDMA/HSPA+/DC-HSPA+: B1, B2, B3, B4, B5, B8
    BPL-031-LTEA-P-TAsia Pacific14G LTE-A:
    B1, B3, B5, B7, B8, B18, B19, B21, B28, B38, B39, B40, B41
    WCDMA/HSPA+/DC-HSPA+: B1, B5, B6, B8, B9, B19
    TD-SCDMA: B39
  • Product CodeDescription
    PVN-LC-05Enables up to 5 PepVPN connections
    ACW-622Pepwave PoE+ Activation Kit
    BPL-031-PRO-LC-SFSpeedFusion Bonding License Key for Balance 30 Pro
    SVL-4431-Year EssentialCare for Balance 30 LTEA / Pro
    SVL-5302-Year EssentialCare for Balance 30 LTEA / Pro
    ICS-0121-Year InControl 2 Subscription
    ICS-0242-Year InControl 2 Subscription
    ANT-MB-22G-S-W-65-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White)
    ANT-MB-22G-S-B-65-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black)
    ANT-MB-02-R-W-62x2 MIMO Wi-Fi Dual Band Antenna (White)
    ANT-MB-02-R-B-62x2 MIMO Wi-Fi Dual Band Antenna (Black)
    • Balance 30 Pro
    • 12V3A Power Supply (ACW-602)
    • 2x LTE Antennas (ACW-815)
    • 4x Wi-Fi Dual Band Antennas (ACW-341)
    • 4x Wi-Fi Antenna Extender with Magnetic Base (ACW-800)
    • 1 Pair of Mounting Brackets (ACW-721)
