Super Adaptable
Fiber, cellular, ethernet, you choose. The possibilities are endless.
Enable Traffic Steering technology
Steer each packet to different connections based on its application. Save high-performance connections for applications that actually need it.
Speed and Reliability without Compromising
With Hot Failover technology, you can switch between Fiber and 5G without users even noticing.
Stay in Control, Anytime, Anywhere
The Balance 310 Fiber 5G is compatible with InControl, giving you better control of your device so you can get things done faster & easier.
Available with PrimeCare
Everything you need to build an enterprise-grade SpeedFusion network in a single subscription.
  • WANSupport for PPPoE, Static IP, DHCP
    WAN Link Health Check
    -PING
    -IPv6 Support
    -DNS Lookup
    -HTTP
    Bandwidth Allowance Monitor
    USB 4G/3G Modem Support
    Intelligent Failover
    -changeip.com
    -dyndns.org
    -no-ip.org
    -tzo.com
    -DNS-O-Matic
    Extended DHCP Option
    DHCP Reservation
    DNS Proxy for LAN Clients
    VLAN on LAN Support
    Session Persistence
    Per-Service Load Distribution
    Multiple Algorithms
    -Weighted
    -Enforced
    -Persistence
    -Priority
    -Overflow
    -Least Used
    -Lowest Latency
    -Fastest Response Time
    SecurityDoS Prevention
    Stateful Firewall
    Web Blocking
    Web Filtering Blacklist
    Site-to-Site VPN
    -Bandwidth Bonding
    -Hot Failover
    -256-bit AES Encryption
    -Dynamic Routing
    PPTP/L2TP/OpenVPN Server
    -Local User Active Directory Authentication
    -X.509 Certificate Support
    Advanced QoS User Groups
    -Bandwidth Reservation
    -Individual Bandwidth Limit
    Application Prioritization
    -By User Groups
    -SIP, HTTPS, VPN QoS
    -Custom Application QoS
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    WINS Server
    VRRP HA Support
    BGP, OSPFv2 and RIPv2 Support
    Auto AP Discovery
    Auto AP Firmware Management
    AP Profile Configuration
    Wi-Fi Usage Statistics
    Support RADIUS Authentication
    Support LDAP Authentication
    DNSBuilt-in Authoritative DNS
    Support for A, CNAME, NS, MX, PTR, SOA, SRV, TXT records
    Command Line Interface
    InControl Cloud Management
    Email Notification
    Active Client & Session Lists
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
  • Product CodeEmbedded
    Modem(s)
    Regions5G BandsLTE Bands
    BPL-310-FBR-5GD-T-PRM1x 5GGlobal5G (NSA) Sub 6Ghz:
    n1, n2, n3, n5, n7, n8, n12, n20,
    n28, n38, n41, n66, n71, n77, n78, n79
    B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17,
    B18, B19, B20, B25, B26, B28, B29, B30, B32, B34,
    B38, B39, B40, B41, B42, B46, B48, B66, B71
    BPL-310-FBR-5GH-T-PRM1x 5GGlobal*5G (NSA) Sub 6Ghz:
    n1, n2, n3, n5, n7, n8, n12, n20, n25,
    n28, n38, n40, n41, n66, n71, n77,
    n78, n79
    BPL-310-FBR-5GN-T-PRM1x 5GGlobal5G (NSA & SA) Sub 6Ghz:
    n1, n2, n3, n5, n7, n8, n12, n13, n14,
    n18, n20, n25, n26, n28, n29, n30, n38,
    n40, n41, n48, n66, n70, n71, n75, n76,
    n77, n78, n79
    *US Carrier Certifications: AT&T, T-Mobile, Verizon (C-Band), FirstNet
  • Product CodeProduct NameDescription
    LIC-VWANVirtual WAN Activation LicenseActivate 1x Virtual WAN on Balance 310 Fiber 5G*
    LIC-2VWANVirtual WAN Activation LicenseActivate 1x Virtual WAN on Balance 310 Fiber 5G*
    LIC-3VWANVirtual WAN Activation LicenseActivate 1x Virtual WAN on Balance 310 Fiber 5G*
    PRM-E-1YPrimeCare E (1-Year) 1-Year PrimeCare
    PRM-E-2YPrimeCare E (2-Year) 2-Year PrimeCare
    PRM-E-4YPrimeCare E (4-Year) 4-Year PrimeCare
    PCP-E-1YPrimeCare+ E (1-Year) 1-Year PrimeCare
    PCP-E-2YPrimeCare+ E (2-Year) 2-Year PrimeCare
    PCP-E-4YPrimeCare+ E (4-Year) 4-Year PrimeCare
    ACW-782Rack Mount for Balance 310 5G / Balance 310 Fiber 5GRack Mount for Balance 310 5G & Balance 310 Fiber 5G with screws
    * Learn more about Virtual WAN Activation License here.
    • Balance 310 Fiber 5G
    • 1x of 12V5A PSU
    • 1x Power Cord (ACW-614)
    • 4x Wi-Fi Dual Band Antennas (ACW-341)
    • 4x LTE/5G Antennas (ACW-235)
    • Rubber Foot Pad set
    • Do you have any suggestions for a 10G SFP transceiver?
      Learn more about the recommended SFP transceiver at this post
