Features
Experience Hot Failover with LTE or 5G
If your network fails, the device will automatically switch over to the cellular connection using LTE or 5G to resume connectivity.
Out-of-Band Management
Remotely manage and troubleshoot your devices all through the convenience of a FlexModule Mini.
Bandwidth-on-Demand with LTE or 5G
Network can be changed from LTE to 5G simply by changing the FlexModule Mini.
SpeedFusion Cloud
meeting your deployment needs
Through just a click of button, your device will activate
SpeedFusion Cloud allowing you to achieve unbreakable connectivity and removing the need for a second endpoint.
LTE-A Module (EXM-MINI-1LTEA)
Interface 1x Embedded LTE-A Cellular Modems
with Redundant SIM Slots
Antenna Connectors 2x SMA Cellular Antenna Connectors Downlink/Uplink Datarate 300Mbps/50Mbps (CAT-6)
600Mbps/150Mbps (CAT-12)
Power Consumption 10W Weight 0.83 pounds | 375 grams LTE-A Module (EXM-MINI-1GLTE-G)
Antenna Connectors 4x SMA Cellular Antenna Connectors Downlink/Uplink Datarate 1.2 Gbps/150 Mbps (CAT-18) Power Consumption 10W Weight 0.83 pounds | 375 grams 5G Module (EXM-MINI-15GH)
Interface 1x Embedded 5G Cellular Modems with
Redundant SIM SlotsAntenna Connectors 4x SMA Cellular Antenna Connectors Downlink/Uplink Datarate ^ 5G: 4 Gbps / 700 Mbps
LTE CAT-20: 2 Gbps / 150 MbpsPower Consumption 10W Weight 0.83 pounds | 375 grams VDSL Module (EXM-MINI-1VDSL)
Interface 1x RJ11 Connector, 1x Status LED Power Consumption 9W Weight 0.44 pounds | 200 grams -
Product Code Carrier/
Categories
Embedded Modem 5G Bands 4G Bands EXM-MINI-15GH Global/5G 1 5G (NSA) Sub 6Ghz:
n1, n2, n3, n5, n28, n41,
n66, n71, n77, n78, n79
5G (SA) Sub 6Ghz:
n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17,
B18, B19, B20, B25, B26, B28, B29, B30, B32, B34,
B38, B39, B40, B41, B42, B43, B46, B48, B66, B71 -
Software Peplink Balance Firmware WAN Support for PPPoE, Static IP, DHCP
WAN Link Health Check
PING
DNS Lookup
HTTP
Bandwidth Allowance Monitor
IPv6 Support
USB 4G/3G Modem Support
changeip.com
dyndns.org
no-ip.org
tzo.com
DNS-O-Matic
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
-Weighted
-Enforced
-Persistence
-Priority
-Overflow
-Least Used
-Lowest Latency
Security DoS Prevention
Stateful Firewall
Web Blocking
Complete VPN Solution SpeedFusion VPN/SpeedFusion Bandwidth Bonding
-Site-to-Site VPN
-Bandwidth Aggregation
-Hot Failover
-256-bit AES Encryption
-Dynamic Routing
-X.509 Certificate Support
PPTP/L2TP/OpenVPN Server
Advanced QoS User Groups
-Bandwidth Reservation
-Individual Bandwidth Limit
Application Prioritization
-By User Groups
-SIP, HTTPS, VPN QoS
-Custom Application QoS
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
BGP, OSPFv2 and RIPv2 Support
Bonjour Forwarding
Auto AP Discovery
Auto AP Firmware Management
AP Profile Configuration
Wi-Fi Usage Statistics
Support RADIUS Authentication
Support LDAP Authentication
DNS Built-in Authoritative DNS
-Support for A, CNAME, NS, MX, PTR, SOA, SRV, TXT Records
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
Power Requirements Universal Input 100V – 240V AC -
Product Code Description SFN-LC-100 Up to 100 SpeedFusion Bonding License Key FIPS-LC-B580 FIPS License for Balance 580 ECP-BPL-380X-1Y EssentialCare+ (1-Year) for Balance 380X ECP-BPL-380X-2Y EssentialCare+ (2-Year) for Balance 380X ECP-BPL-380X-4Y EssentialCare+ (4-Year) for Balance 380X SVL-BPL-380X-1Y 1-Year EssentialCare for Balance 380X SVL-BPL-380X-2Y 2-Year EssentialCare for Balance 380X ECP-BPL-580X-1Y EssentialCare+ (1-Year) for Balance 580X ECP-BPL-580X-2Y EssentialCare+ (2-Year) for Balance 580X ECP-BPL-580X-4Y EssentialCare+ (4-Year) for Balance 580X SVL-BPL-580X-1Y 1-Year EssentialCare for Balance 580X SVL-BPL-580X-2Y 2-Year EssentialCare for Balance 580X LIC-VWAN Activate 1x Virtual WAN LIC-2VWAN Activate 2x Virtual WAN LIC-3VWAN Activate 3x Virtual WAN -
Product Code Product Name Product Description BPL-380X Balance 380X Balance 380X, 3x GE WAN ports and 3x GE LAN ports.
SpeedFusion capableBPL-580X Balance 580X Balance 580X, 5x GE WAN ports and 3x GE LAN ports.
SpeedFusion capableEXM-MINI-1LTEA FlexModule Mini LTEA (CAT-6 / CAT-12) Expansion Module with 1x LTE-A (CAT-6 / CAT-12) modem EXM-MINI-1GLTE-G FlexModule Mini LTEA (CAT-18) Expansion Module with 1x LTE-A Pro (CAT-18) modem
EXM-MINI-15GH FlexModule Mini 5G Expansion Module with 1x 5G modem -
- Balance 380X / Balance 580X
- Power Cord (ACW-614)
- 1 Pair of Mounting Brackets
- Rubber Foot Pad set
- LTE-A Module (EXM-MINI-1LTEA)
- 2x LTE/5G Antennas (ACW-234)
- LTE-A Module (EXM-MINI-1GLTE-G)
- 4x LTE/5G Antennas (ACW-234)
- 5G Module (EXM-MINI-15GH)
- 4x LTE/5G Antennas (ACW-235)
