BR1 Mini
Durable. Unbeatable Price Performance.
Just one remarkable device
Engineered with the highest quality build in mind. Sleek outside, yet ruggedized inside, this device has been built to withstand whatever deployment scenario thrown at it.
Stay in touch with InTouch
InTouch extends your reach to third party devices connected to the BR1 Mini. Remotely view, configure or troubleshoot third party devices, all within the InControl 2 environment, eliminating the need for a separate and costly OOBM infrastructure.
Manage with confidence
Control the BR1 Mini using InControl 2 cloud-based endpoint management system. Generate useful reports and push configurations, as you remotely access any Peplink device with ease.
Use Cases
POS Failover / Retail
Branch / Kiosks / IoT
VoIP / Remote Work
Mobile Vehicles / Utilities
Why BR1 Mini?
Remote Access to Third Party Device Interface (InTouch)
Other Solutions
will require network engineers to maintain and be costly
VS
Our BR1 Mini
enables access to linked devices through a single platform
Seamless Connection Transfer Without Interruption (Hot Failover)
Other Solutions
will experience network interruptions
VS
Our BR1 Mini
provides seamless network connectivity
Option to Enable Additional Features (Optional Subscription)
Other Solutions
require licenses for features or otherwise lock the device
VS
Our BR1 Mini
offers an optional package inclusive of several features
Improve your Video and Collaboration (Smoothing)
Other Solutions
may experience jitter and delays
VS
Our BR1 Mini
improves the quality of real-time applications such as Zoom / Teams
Private LTE Network Availability (CAT-7)
Other Solutions
operate within limited bands that don’t have access to private LTE
VS
Our BR1 Mini
can operate within LTE bands dedicated to private LTE networks
Privately Hosted Management Platform (On-Premise Network)
Other Solutions
are managed only through cloud-based platforms
VS
Our BR1 Mini
can be managed through a platform hosted on private server hardware
Now Available on PrimeCare
Launching the BR1 Mini on PrimeCare^, giving the device prime access to InControl 2, eSIM compatibilities*, increased VPN throughput, more PepVPN peers, WAN Activation, Wi-Fi WAN, Hot Failover, Smoothing, and standard warranty & support.
* eSIM available with Firmware 8.4.0 or above.
^ With Firmware 8.3.1, PrimeCare includes all feature pack features (WAN Activation, Wi-Fi WAN, Hot Failover & Smoothing).
Plug and play, anyone?
SpeedFusion Connect* services makes the BR1 Mini the ultimate plug-and-play device. Power up, switch on, and get connected. SpeedFusion Connect also works with Peplink technologies such as Hot Failover^, ensuring reliable connectivity is accessible at all times.
* SpeedFusion Connect is available in select countries and regions. Learn more.
^ PrimeCare is required to utilize the benefits of Peplink technology and services.
Ports and Connections
* Available in firmware 8.3.0.
Photos
WAN Link Health Check
Bandwidth Allowance Monitor
Support for Dynamic DNS servicesLAN DHCP Server for LAN Clients
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
-Weighted Balance
-Priority
-Overflow
-Persistence
-Least Used
-Lowest Latency
-Enforced
-Fastest Response Time
SpeedFusion
- Site-to-Site VPN
- SpeedFusion Hot Failover^
- SpeedFusion WAN Smoothing^
- 256-bit AES Encryption
- Pre-shared Key Authentication
- Dynamic Routing
- PPTP VPN Server
- RADIUS, LDAP Authentication
IPsec VPN (Network-to-Network)@Networking NAT and IP Forwarding
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
Security 128-bit WEP
WPA & WPA 2
Stateful Firewall
DoS Prevention
Web Blocking
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoS
Global Positioning System Integrated GPS
Device Location Map
Captive Portal Support Support for Wired and Wireless LAN Clients
Support RADIUS Authentication
Social Wi-Fi Hotspot support
External Captive Portal supportCertifications FCC, CE, RoHS
Command Line Interface
InControl Cloud Management
Email Notification
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
^ Feature is available as an upgrade.
@ IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices. -
Product Code Embedded
Modem(s)Regions LTE Bands 3G Bands MAX-BR1-MINI-LTEA-US-T-PRM 1x CAT-7 North America# , B2, B4, B5, B7, B12, B13, B14, B25,
B26, B41, B42, B43, B48, B66, B71HSPA+: B2, B4, B5 MAX-BR1-MINI-LTEA-US-DC-T-PRM@ 1x CAT-7 North America# , B2, B4, B5, B7, B12, B13, B14, B25,
B26, B41, B42, B43, B48, B66, B71HSPA+: B2, B4, B5 MAX-BR1-MINI-LTEA-E-T-PRM 1x CAT-7 APAC, EMEA B1, B3, B7, B8, B20, B28, B32, B38, B40, B41, B42, B43 HSPA+: B1, B5, B8 MAX-BR1-MINI-LTEA-B-T-PRM 1x CAT-6 APAC, EMEA B1, B2, B3, B4, B5, B7, B8, B12,
B13, B14, B17, B18, B19, B20,
B25, B26, B28, B29, B30, B38,
B39, B40, B41, B42, B43, B48,
B66, B71HSPA+/WCDMA: B1, B2, B4,
B5, B6, B8, B9, B19MAX-BR1-MINI-LTEA-B-T-JPC-PRM 1x CAT-6 Japan B1, B2, B3, B4, B5, B7, B8, B12, B13,
B28, B29, B30, B38, B39, B40, B41,
B42, B43, B48, B66, B71HSPA+/WCDMA: B1, B2, B4,
B5, B6, B8, B9, B19MAX-BR1-MINI-LTE-US-T-PRM 1x CAT-4 North America^ B2, B4, B5, B12, B13, B14, B66, B71 WCDMA/HSPA+/DC-HSPA+: B2, B5 MAX-BR1-MINI-LTE-E-T-PRM 1x CAT-4 APAC, EMEA B1, B3, B5, B7, B8, B20, B38, B40, B41 WCDMA/HSPA+/DC-HSPA+: B1, B5, B8 MAX-BR1-MINI-LTE-MX-T-PRM 1x CAT-4 APAC, Latin America,
AustraliaB1, B2, B3, B4, B5, B7, B8, B28, B40 WCDMA/HSPA+/DC-HSPA+: B1, B2, B5, B8 # US Carrier Certifications: AT&T, FirstNet, T-Mobile, US Cellular, Verizon
* US Carrier Certifications: AT&T, T-Mobile (Pending), Verizon.
^ US Carrier Certifications: AT&T, T-Mobile, Verizon.@ Comes with a DC power cable instead of the regular 4 Pin Power Supply.
Regions are for reference only. For specific location compatibility, please refer to the bands.
Product Code Description PRM-A-1Y PrimeCare A (1-Year) PRM-A-2Y PrimeCare A (2-Year) PRM-A-4Y PrimeCare A (4-Year) PCP-A-1Y PrimeCare+ A (1-Year) PCP-A-2Y PrimeCare+ A (2-Year) PCP-A-4Y PrimeCare+ A (4-Year) MAX-BR1-MINI-LC-FP Feature pack for BR1 Mini enables Ethernet WAN, Wi-Fi WAN, Hot Failover, Smoothing, GPIO and Ignition Sensing ANT-MB-22G-S-B-6 5-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black) ANT-MB-22G-S-W-6 5-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White) ACW-634 10ft DC Power Cable ACW-643 Vehicle Cigarette to Molex Power Cable ACW-DIN-BR1-MINI DIN Rail Mount MAX-BR1-MINI-BD-FP-2Y MAX BR1 Mini Bundle Offer – 2 year PrimeCare extension with complimentary Feature Pack MAX-BR1-MINI-BD-FP-4Y MAX BR1 Mini Bundle Offer – 4 year PrimeCare extension with complimentary Feature Pack MAX-BR1-MINI-BD-FP-PLUS-2Y MAX BR1 Mini Bundle Offer – 2 year PrimeCare+ extension with complimentary Feature Pack MAX-BR1-MINI-BD-FP-PLUS-4Y MAX BR1 Mini Bundle Offer – 4 year PrimeCare+ extension with complimentary Feature Pack LIC-VWAN Activate 1x Virtual WAN LIC-2VWAN Activate 2x Virtual WAN LIC-3VWAN Activate 3x Virtual WAN -
MAX BR1 Mini
- MAX BR1 Mini (HW3)
- 2x LTE Antennas (ACW-235)
- 2x Wi-Fi Dual Band Antennas (ACW-342)
- 1x GPS Active Antenna (ACW-232)
- 1x 12V 2A 4 Pin Power Supply (ACW-632)
MAX BR1 Mini (MAX-BR1-MINI-LTEA-B-T-JPC-PRM)
- 2x iAN067 LTE Antennas
