BR1 Mini M2M
Reliability in a small package
Engineered toward Industrial Devices
Featuring an RS-232/RS-485 serial port, the BR1 Mini M2M is your best solution to bring connectivity to versatile industrial equipment and IoT device.
Our advanced InTouch technology allows for secure remote monitoring and management of your linked industrial device through a single cloud platform.
Flexibility in Power and Ports
Power the device with PoE, Micro-Fit or our 4-pin to USB-C power cable allowing for flexible installations and portable deployments.
Don’t limit yourself to a single device. The BR1 Mini M2M supports dual serial port Y-cables for even more efficiency.
Instant Connectivity
Gone are the days of agonizing over which cellular service to choose or needing to manage physical SIM cards. Experience instant cellular connectivity with a subscription to our eSIM-based SFC 5G/LTE data plans. Leave the troubles to us while you concentrate on what truly matters.
Improved Dual-band Wi-Fi
Deploy more devices in the same location with no worry of network congestion. Have the option to collect data from your IoT machines from afar, helping admins save time and stay safe.
Ruggedized and Reliable
The BR1 Mini M2M is built for maintaining a stable connection while withstanding tough environments, such as factories, power plants and outdoor deployments.
*Certification pending.
Ports and Connections
Photos
WAN Link Health Check
Bandwidth Allowance Monitor
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Security Stateful Firewall
DoS Prevention
Web Blocking
Complete VPN Solution SpeedFusion VPN/SpeedFusion
-Hot Failover
-Site-to-Site VPN
-Hot Failover
-256-bit AES Encryption
IPsec VPN (Network-to-Network)^
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoSNetworking NAT and IP Forwarding
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
Captive Portal Support for Wired and Wireless LAN clients
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
Product Code Region | Carrier Embedded Modem 4G Bands 3G Bands MAX-BR1-MINI-M2M-LTE-US-T-PRM
North America*
1 x CAT 4 B2, B4, B5, B12, B13, B14, B66, B71 WCDMA/HSPA+/DC-HSPA+:
B2, B5MAX-BR1-MINI-M2M-LTE-E-T-PRM
APAC, EMEA 1 x CAT 4 B1, B3, B5, B7, B8, B20, B38, B40, B41 WCDMA/HSPA+/DC-HSPA+:
B1, B5, B8MAX-BR1-MINI-M2M-LTE-MX-T-PRM APAC, Latin America,
Malaysia, Indonesia1 x CAT 4 B1, B2, B3, B4, B5, B7, B8, B28, B40 WCDMA/HSPA+/DC-HSPA+:
B1, B2, B5, B8
*US Carrier Certifications: AT&T, T-Mobile, Verizon, FirstNet -
Product Code Product Name PRM-A-1Y / PCP-A-1Y PrimeCare A / PrimeCare+ A (1-Year) PRM-A-2Y / PCP-A-2Y PrimeCare A / PrimeCare+ A (2-Year) PRM-A-4Y / PCP-A-4Y PrimeCare A / PrimeCare+ A (4-Year) MAX-BR1-MINI-LC-FP Feature pack for BR1 Mini M2M enables Ethernet WAN, Wi-Fi WAN, Hot Failover, Smoothing and
Bandwidth BondingANT-MB-22G-S-B-6 5-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black) ANT-MB-22G-S-W-6 5-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White) ACW-634 10ft DC Power Cable ACW-790 Dual Serial Y-Cable ACW-791 4-Pin Micro-fit Connector to USB-C Power Cable ACW-DIN-BR1-MINI DIN Rail mount kit -
- 1x BR1 Mini M2M
- 2x LTE Antennas (ACW-235)
- 2x Dual Band Wi-Fi Antennas (ACW-342)
- 1x GPS Active Antenna (ACW-232)
- 1x 12V 2A 4pin Power Supply (ACW-632)
