BR1 Mini 5G
Affordable, Long-lasting 5G
for Mass Deployments
Model:
4G connectivity might work fine today, but the switch to 5G is inevitable.
Futureproof your network with the latest 5G technology, and keep your network running
for many years to come.
A single SKU for global
deployments
Extensive list of compatible 5G/LTE bands.
Native 5G NSA and SA mode support.
Extensive list of compatible 5G/LTE bands. Native 5G NSA and SA mode support.
Private 5G Support
Adding devices to your Private 5G network is no longer a hassle.
Integration can be as simple as plug and play.
One device to do it all
Bring 5G Wi-Fi to your setup with a single compact device. This means simpler networks, lower costs and fewer points of failure.
Utilize Wi-Fi WAN for Added Reliability
Take an existing Wi-Fi connection and use it as an additional
WAN for yourself.
Having multiple redundant WANs helps ensure your connection
stays up when your 5G or wired connection falters.
⯈ 5G Adapter
⯈ Gateway/Router
Have an existing network? Add the BR1 Mini 5G as a
5G adapter with zero hassle. Need something more? The device can
also act as a gateway/router for multiple WANs.
Stay in touch with InTouch
Access connected devices, like sensors and cameras, with out of band management at 5G speed.
Monitor your entire network from a single screen
Remotely access your Peplink devices’ web admin with InControl 2, our cloud-based endpoint management system.
Generate reports and push
configurations for more effective management.
Generate reports and push configurations for more effective management.
⯈ Key BR1
Mini 5G Benefit
An exceptionally reliable, rugged 5G Cellular Router that connects
your data and Internet applications – wherever they are.
#1
Future-proof Connectivity
With the latest cellular LTE and 5G via SIM
or eSIM and a second optional Ethernet
WAN , the BR1 Mini 5G connects your Ethernet devices with up to 300Mbps throughput.
#2
Ruggedized and Reliable
Built in a rugged & reliable metal case
with
fanless, ventless design
certified for shock and vibration resistance for deployment virtually anywhere.
#3
Designed for Remote Operation
With central management via Peplink
InControl 2
and local device management via Peplink
InTouch , the BR1 Mini saves time and reduces field visits.
⯈ Use Cases
POS
IoT, Kiosk, Remote
Surveillance
Mobility
Remote Work
Port and Connections
1x GE LAN port with 802.3at PoE input
Power Port with GPIO & Ignition Sensing
1x GE WAN/LAN port[ 1 ]
1x 5G Modem
Wi-Fi 5
1. Available with a feature pack add-on license or a PrimeCare subscription.
WAN Link Health Check
Bandwidth Allowance Monitor
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Security Stateful Firewall
DoS Prevention
Web Blocking
-Site-to-Site VPN
-Hot Failover
-256-bit AES Encryption
IPsec VPN (Network-to-Network)^
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoSNetworking NAT and IP Forwarding
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
Captive Portal Support Support for Wired LAN clients
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
^ IPsec VPN supports connection with Cisco, Juniper, Peplink devices.
* Wi-Fi functionality is only available on BR1 Mini 5G (HW2). -
Product Code Embedded Modem Region 5G Bands LTE Bands MAX-BR1-MINI-5GN-T-M-PRM 1x 5G
Global*
*US Carrier Certifications: AT&T, T-Mobile,
Verizon, FirstNet5G (NSA & SA) Sub 6Ghz:
n1, n2, n3, n5, n7, n8, n12, n13, n14, n18, n20, n25, n26, n28, n29, n30, n38, n40, n41, n48, n66, n70, n71, n75, n76, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B43, B46, B48, B66, B71 MAX-BR1-MINI-5GN-T-PRM (With Wi-Fi) 1x 5G
Global*
n1, n2, n3, n5, n7, n8, n12, n13, n14, n18, n20, n25, n26, n28, n29, n30, n38, n40, n41, n48, n66, n70, n71, n75, n76, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B43, B46, B48, B66, B71 -
Product Code Descriptions PRM-A-1Y PrimeCare A (1-Year) PRM-A-2Y PrimeCare A (2-Year) PRM-A-4Y PrimeCare A (4-Year) PCP-A-1Y PrimeCare+ A (1-Year) PCP-A-2Y PrimeCare+ A (2-Year) PCP-A-4Y PrimeCare+ A (4-Year) MAX-BR1-MINI-LC-FP Feature pack for BR1 Mini enables Ethernet WAN, Hot Failover, Smoothing, Bandwidth Bonding MAX-BR1-MINI-BD-FP-2Y MAX BR1 Mini Bundle Offer – 2 year PrimeCare extension & complimentary feature pack MAX-BR1-MINI-BD-FP-4Y MAX BR1 Mini Bundle Offer – 4 year PrimeCare extension & complimentary feature pack MAX-BR1-MINI-BD-FP-PLUS-2Y MAX BR1 Mini Bundle Offer – 2 year PrimeCare+ extension & complimentary feature pack MAX-BR1-MINI-BD-FP-PLUS-4Y MAX BR1 Mini Bundle Offer – 4 year PrimeCare+ extension & complimentary feature pack ACW-634 10ft DC Power Cable ACW-DIN-BR1-MINI DIN Rail mount kit ANT-SLM-40G-S-B-6 Slim 40G – 4×4 MIMO 5G Ready Cellular Antenna System with GPS (Black) ANT-MB-40G-S-W-6 Mobility 40G – 4×4 MIMO 5G Ready Cellular Antenna System with GPS (White) ANT-MB-40G-S-B-6 Mobility 40G – 4×4 MIMO 5G Ready Cellular Antenna System with GPS (Black) -
For MAX-BR1-MINI-5GN-T-M-PRM
- 1x BR1 Mini 5G
- 4x LTE/5G Antennas (ACW-235)
- 1x 12V 2A 4pin Power Supply (ACW-632)
For MAX-BR1-MINI-5GN-T-PRM (With Wi-Fi)
- 1x BR1 Mini 5G (HW2)
- 2x Dual Band Wi-Fi Antennas (ACW-342)
