Sonic for a Reason
The ‘classic goes sonic’, why? The BR1 Pro 5G is integrated with the new generation multi-core CPU ensuring delivery of gigabit speeds. Achieving 8 times faster than the original BR1 classic.
Why Settle For An Adapter When You Can Get The Full Suite?
5G Adapter
Need a simple 5G adapter? Add a 5G WAN to any existing router or firewall without the need to replace any of your devices.
5G Router / Gateway
Why stop there? It can also serve as a powerful 5G router for your network. No matter if it’s C-Band or LTE, you’ll be able to add cellular connectivity easily to your network.
Fixed or Mobile
Supercharged with SpeedFusion, use the BR1 Pro 5G as the central router for your branch network. Guarantee unbreakable connections for important applications, like video calls, POS systems and more.
Wi-Fi 6
Experience less interference and connect to multiple devices simultaneously.
Deploy with Confidence
Just like the original BR1 Classic, the BR1 Pro 5G has also been certified to meet the standards of a wide array of deployment criterias.
Low-Profile Form Factor
At 1.15 inches short, the BR1 Pro 5G is 25% slimmer than the BR1 Classic.
Ports and Connections
Photos
Product Overview & Comparison Table
Deep Dive
| Software | Pepwave MAX Firmware |
| WAN | Support for PPPoE, Static IP, DHCP WAN Link Health Check Bandwidth Allowance Monitor Support for Dynamic DNS services WAN Port Convertible into LAN Port |
| Load Balancing | Multiple Outbound Policy Algorithms • Weighted Balance • Priority • Overflow • Persistence • Least Used • Lowest Latency • Enforced • Fastest Response Time |
| Security | Stateful Firewall DoS Prevention Web Blocking |
| Complete VPN Solution | SpeedFusion VPN • Site-to-Site VPN • 256-bit AES Encryption • Pre-shared Key Authentication • Dynamic Routing X.509 Certificate Support * IPsec VPN (Network-to-Network) ^ Remote User Access (PPTP/L2TP/OpenVPN) |
| Advanced QoS | Individual Bandwidth Limit Application Prioritization • SIP, HTTPS, VPN QoS • Custom Application QoS |
| Edge Computing | Support on Applications and Docker (HW3+) |
| Global Positioning System | Integrated GPS Device Location Map Location Tracking Data with InControl 2 Fleet Management with InControl 2 |
| Networking | NAT and IP Forwarding Static Routes Port Forwarding Many to One, One to One NAT NAT Pool SIP ALG, H.323 ALG UPnP, NAT-PMP |
| AP Controller | Support for Peplink AP Series Auto AP Discovery Auto AP Firmware Management AP Profile Configuration Wi-Fi Usage Statistics |
| Captive Portal Support | Support for Wired LAN clients Support RADIUS Authentication Time and Usage Quotas on Open Access Mode Built-in Customizable Splash Page |
| Device Management | Web Administrative Interface Command Line Interface InControl 2 Cloud Management Email Notification Active Client & Session Lists Bandwidth Usage Statistics Syslog Service SNMP v1, v2c and v3 |
Ordering Information
| Product Code | Embedded Modem | Region | 5G Bands | LTE Bands |
| MAX-BR1-PRO-5GN-T-PRM | 1x 5G | Global* *US Carrier Certifications: AT&T, T-Mobile, Verizon, FirstNet | 5G (NSA & SA) Sub 6Ghz: n1, n2, n3, n5, n7, n8, n12, n13, n14, n18, n20, n25, n26, n28, n29, n30, n38, n40, n41, n48, n66, n70, n71, n75, n76, n77, n78, n79 | B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B43, B46, B48, B66, B71 |
| MAX-BR1-PRO-5GK-T-PRM | 1x 5G | Global* *US Carrier Certifications: AT&T, T-Mobile, Verizon, FirstNet | 5G (NSA & SA) Sub 6Ghz: n1, n2, n3, n5, n7, n8, n12, n13, n14, n18, n20, n25, n26, n28, n29, n30, n38, n40, n41, n48, n66, n71, n75, n76, n77, n78, n79 | B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B43, B46, B48, B66, B71 |
User Feedback
“I live in the mountains and was getting 1 or 2 bars @ 300-500 Mbps on my regular mobile hotspot. I connected the exterior antenna to my Peplink MAX BR1 Pro 5G and now I’m getting 4 bars @ 1200 Mbps. Tremendous improvement in connectivity, even in the most remote locations.”
– Amazon.com Customer
Feature Add - On
| PRM-C-1Y | PrimeCare C (1-Year) |
| PRM-C-2Y | PrimeCare C (2-Year) |
| PRM-C-4Y | PrimeCare C (4-Year) |
| PCP-C-1Y | PrimeCare+ C (1-Year) |
| PCP-C-2Y | PrimeCare+ C (2-Year) |
| PCP-C-4Y | PrimeCare+ C (4-Year) |
| ACW-634 | 10ft DC Power Cable |
| ACW-643 | Vehicle Cigarette to Molex Power Cable |
| ACW-791 | Peplink 4-Pin to USB-C Power Cable |
| ACW-DIN-BR1 | DIN Rail Mount for BR1 Pro and BR1 Mini Series |
| ANT-SLM-40G-S-B-6 | Slim 40G - 4x4 MIMO 5G Ready Cellular Antenna System with GPS (Black) |
| ANT-MB-42G-S-W-6 | Mobility 42G - 4x4 MIMO 5G Ready Cellular and Wi-Fi Antenna System with GPS (White) |
| ANT-MB-42G-S-B-6 | Mobility 42G - 4x4 MIMO 5G Ready Cellular and Wi-Fi Antenna System with GPS (Black) |
| ANT-MAX | Antenna MAX - Enclosed with 4x LTE/5G, 2x Wi-Fi, 1x GPS 600-6000MHz, IP67, SMA male (Cellular, GPS), RP-SMA male (Wi-Fi), White |
| ANT-MAX-S | Antenna MAX S - IP-rated integrated antenna enclosure for hybrid cellular and Starlink Mini connectivity |
Package Content
- 1x BR1 Pro 5G
- 1x 12V2A Power Supply (ACW-632)
- 4x LTE/5G Antennas (ACW-235)
- 2x Wi-Fi Dual Band Antenna (ACW-341)
- 1x GPS Antenna (ACW-232)
Datasheet / Resources
- Peplink MAX BR1 Pro 5G
- User Manual
- FAQ
- Hardware Reference Guide
- Doubling Down on the Speed and Reliability of a Race Car
- Metro Corporation Rides on Reliable Connectivity for Light Rail
- Cyprus Public Transport Carries 5G Connectivity for Passenger Wi-Fi
- Starlink with Peplink
- Discount Store Chains Finds Connectivity Savings with Peplink
- SpeedFusion Disaster Recovery on Alarm Monitoring System
- Student Dormitories House Reliable Connectivity Through an MSP
