Ready for Any Environment
Fanless Design
Thrives in high-particle environments that would break other fan-based routers.
8×802.3at PoE Outputs
Power your IP phones, cameras, and access points.
Robust Metal Enclosure
Same dimensions as the previous HD4, so it can fit seamlessly into any of your previous deployments.
Compatible With:
Compatible on all major carriers. Certified with Verizon* and T-Mobile.
*Not applicable to MAX-HD2-MBX-5GH-T. Verizon Certification is in progress.
Ideal for On-The-Go Deployments
Ignition Sensing gives it the ability to turn on and off depending on whether the vehicle has started. Upon vehicle shutdown, the MBX can also shut down after a user-defined interval, saving the battery from excessive drain.
The HD4 MBX also supports the optional SIM Injector, which adds another 8 cellular providers to connect with. This mitigates weak spots in cellular coverage, ensuring consistent connectivity . If your deployment crosses national boundaries, you can also use the SIM Injector to load multiple SIM cards, preventing roaming charges.
FirstNet Ready & ESN Certified
FirstNet (band 14) provides first responders with a dedicated network with more priority and network capacity. The HD4 MBX supports band 14, providing additional coverage as the situation demands.
Device has been also certified by UK’s Emergency Services Network (ESN).
Future Proof Design. Ready for 5G
Right out of the box, the HD4 MBX supports 5G. For future technologies, the MBX features a swappable cellular module, so when you need to upgrade to 5G, you can simply swap your old one with a new one. The MBX is also capable of 2.5Gbps of throughput, giving you plenty of bandwidth for Gigabit Ethernet, 5G, or any future mobile technologies.
Pair with the 5G Ready Outdoor Antenna
The 5G ready Outdoor Antenna is suited to a wide range of outdoor public safety, mobile healthcare and even transportation deployments. It has support for extensive 5G global cellular frequencies including Band 71, ensuring enhanced reliability and coverage for any business-critical application.
Use Cases
The HD4 MBX Fits in a Variety of Scenarios
Live Streaming
Telemedicine
Branch Offices
Temporary Sites
Wi-Fi for Employees
Public Safety
Event Live Streaming and Connectivity
The cellular SpeedFusion SD-WAN connection provides all the bandwidth you need to stream HD video. What’s more, our patented WAN Smoothing technology compensates for packet loss, ensuring smooth, jitter-free streaming.
Telemedicine
Using SpeedFusion, the HD4 MBX can combine the bandwidth of 4x Gigabit cellular connections to form a fast and reliable VPN connection that can handle the requirements of remote diagnosis, that requires large amounts of data, more data than a single cellular link can transfer in a timely manner.
Branch Offices
The HD4 MBX supports up to 8x 802.3at PoE connections, enabling you to connect your IP phones, IP cameras, and access points with minimal cabling. It also delivers 802.11ac Wi-Fi with a customizable captive portal for guest access. The HD4 MBX comes equipped with SpeedFusion WAN Smoothing, mitigating packet loss and ensuring that your videoconferences are jitter-free.
Temporary Sites
By combining the bandwidth of up to 4x Gigabit cellular connections, you can perform fast and reliable connectivity no matter where the site is located. Quickly and safely transmit project data, emails, plans, and blueprints between personnel, sites, and headquarters.
Wi-Fi on Employee Shuttles
Peplink ecosystem has all features that are needed for a successful employee bus deployments. It combines the bandwidth of 4x Gigabit cellular connections on a packet level, ensuring employee productivity remains uninterrupted when cellular connections break. With HD4 MBX you can also simplify your cabling since it supports 802.3at PoE standard. Moreover you can also incorporate Smart Readers and TA system to your deployment this way controlling bus access and tracking employee usage.
Public Safety
The HD4 MBX combines the bandwidth of 4x Gigabit cellular links into a fast, reliable, and secure SD-WAN connection, enabling you to stream high-definition video in real-time. This can all be achieved without investing in any infrastructure. With SpeedFusion-enabled devices on multiple vehicles and aerial resources, you can monitor the situation from multiple perspectives without needing a line-of-sight connection.
#PowerofPeplink in Action
Experience on-demand connectivity with SpeedFusion Connect
Enabling the benefits of SpeedFusion has just gotten easier with SpeedFusion Connect. Allowing you to leverage the 5G of multiple connections and SpeedFusion technologies all under one subscription. Enabling backup connectivity has never been so simple!
*Compatible for use in the US and selected regions in Europe
Ports and Connections
WAN Link Health Check
PING
IPv6 Support
DNS Lookup
HTTP
Bandwidth Allowance Monitor
USB 4G/3G Modem Support
Intelligent Failover
changeip.com
dyndns.org
no-ip.org
tzo.com
DNS-O-Matic
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Per-Port VLAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
Weighted
Enforced
Persistence
Priority
Overflow
Least Used
Lowest Latency
Fastest Response Time
Site-to-Site VPN
Bandwidth Bonding
Hot Failover
256-bit AES Encryption
Pre-shared Key Authentication
Dynamic Routing
PPTP VPN Server
RADIUS, LDAP Authentication
X.509 Certificate Support
Advanced QoS User Groups
Bandwidth Reservation
Individual Bandwidth Limit
Application Prioritization
By User Groups
SIP, HTTPS, VPN QoS
Custom Application QoS
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
VRRP HA Support
BGP, OSPFv2 and RIPv2 Support
AP Controller Auto AP Discovery
Auto AP Firmware Management
AP Profile Configuration
Wi-Fi Usage Statistics
Security DoS Prevention
Stateful Firewall
Web Blocking
Web Filtering Blacklist
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
Product Code Carrier
Modems 4G Bands 3G Bands MAX-HD2-MBX-LTEA-R-T America / FirstNet Ready /
CAT-122 B1, B2, B3, B4, B5, B7, B8, B9, B12, B13,
B14, B18, B19, B20, B26, B29, B30, B32,
B41, B42, B43, B46, B48, B66B1, B2, B4, B5, B6, B8, B9, B19 MAX-HD2-MBX-LTEA-D-T APAC & EMEA / CAT-12 2 B1, B2, B3, B4, B5, B7, B8, B9, B12, B13,
B14, B17, B18, B19, B20, B21, B25, B26,
B28, B29, B30, B32, B38, B39, B40, B41,
B66B1, B2, B4, B5, B6, B8, B9, B19 MAX-HD2-MBX-LTEA-Q-T APAC & EMEA / CAT-12 2 B1, B2, B3, B4, B5, B7, B8, B12, B13,
B28, B29, B30, B38, B39, B40, B41,
B42, B43, B48, B66, B71B1, B2, B4, B5, B8, B9, B19 MAX-HD4-MBX-LTEA-R-T America / FirstNet Ready /
CAT-12
4 B1, B2, B3, B4, B5, B7, B8, B9, B12, B13,
B1, B2, B4, B5, B6, B8, B9, B19 MAX-HD4-MBX-LTEA-D-T APAC & EMEA / CAT-12 4 B1, B2, B3, B4, B5, B7, B8, B9, B12, B13,
B66B1, B2, B4, B5, B6, B8, B9, B19 MAX-HD4-MBX-LTEA-Q-T APAC & EMEA / CAT-12 4 B1, B2, B3, B4, B5, B7, B8, B12, B13,
B42, B43, B48, B66, B71B1, B2, B4, B5, B8, B9, B19 MAX-HD2-MBX-GLTE-S-T
Global /
CAT-20
2 B1, B2, B3, B4, B5, B7, B8, B12, B13, B14,
B30, B32, B34, B38, B39, B40, B41, B42,
B46 (LAA), B48, B66, B71HSPA+/WCDMA: B1, B2, B3, B4,
B5, B6, B8, B9, B19MAX-HD4-MBX-GLTE-S-T Global /
FirstNet /
CAT-204 B1, B2, B3, B4, B5, B7, B8, B12, B13, B14,
B5, B6, B8, B9, B19MAX-HD2-MBX-ESN-GLTE-S-T
Global / ESN
CAT-20
B5, B6, B8, B9, B19MAX-HD4-MBX-ESN-GLTE-S-T Global / ESN
CAT-20
B5, B6, B8, B9, B19* China & HK TD LTE are excluded.
Product Code Embedded Modem Region 5G Bands LTE Bands MAX-HD2-MBX-5GD-T 2x 5G
Global 5G (NSA) Sub 6Ghz:
n1, n2, n3, n5, n7, n8, n12, n20, n28, n38, n41, n66, n71, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B46, B48, B66, B71 MAX-HD2-MBX-5GN-T 2x 5G
Global 5G (NSA & SA) Sub 6Ghz:
n1, n2, n3, n5, n7, n8, n12, n13, n14, n18, n20, n25, n26, n28, n29, n30, n38, n40, n41, n48, n66, n70, n71, n75, n76, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B43, B46, B48, B66, B71 MAX-HD4-MBX-5GD-T 4x 5G
n1, n2, n3, n5, n7, n8, n12, n20, n28, n38, n41, n66, n71, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B46, B48, B66, B71 MAX-HD4-MBX-5GN-T 4x 5G
Global*
*US Carrier Certifications: AT&T, T-Mobile, Verizon, FirstNet”5G (NSA & SA) Sub 6Ghz:
n1, n2, n3, n5, n7, n8, n12, n13, n14, n18, n20, n25, n26, n28, n29, n30, n38, n40, n41, n48, n66, n70, n71, n75, n76, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B43, B46, B48, B66, B71 MAX-HD4-MBX-5GK-T 4x 5G
North America*
*US Carrier Certifications: AT&T, T-Mobile, Verizon, FirstNet5G (NSA & SA) Sub 6Ghz:
n1, n2, n3, n5, n7, n8, n12, n13, n14, n18, n20, n25, n26, n28, n29, n30, n38, n40, n41, n48, n66, n71, n75, n76, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B43, B46, B48, B66, B71 -
Product Code Embedded Modem Region 5G Bands LTE Bands EXM-MBX-T2-5GD 2x 5G Global 5G (NSA) Sub 6Ghz:
n1, n2, n3, n5, n7, n8, n12, n20, n28, n38, n41, n66, n71, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B46, B48, B66, B71 EXM-MBX-T2-5GH 2x 5G Global 5G (NSA) Sub 6Ghz:
n1, n2, n3, n5, n28, n41, n66, n71, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B46, B48, B66, B71 EXM-MBX-T2-5GN 2x 5G Global 5G (NSA & SA) Sub 6Ghz:
n1, n2, n3, n5, n7, n8, n12, n13, n14, n18, n20, n25, n26, n28, n29, n30, n38, n40, n41, n48, n66, n70, n71, n75, n76, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B43, B46, B48, B66, B71 EXM-MBX-T4-5GD 4x 5G Global 5G (NSA) Sub 6Ghz:
n1, n2, n3, n5, n7, n8, n12, n20, n28, n38, n41, n66, n71, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B46, B48, B66, B71 EXM-MBX-T4-5GH 4x 5G Global 5G (NSA) Sub 6Ghz:
n1, n2, n3, n5, n28, n41, n66, n71, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B46, B48, B66, B71 EXM-MBX-T4-5GN 4x 5G Global 5G (NSA & SA) Sub 6Ghz:
n1, n2, n3, n5, n7, n8, n12, n13, n14, n18, n20, n25, n26, n28, n29, n30, n38, n40, n41, n48, n66, n70, n71, n75, n76, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B43, B46, B48, B66, B71 EXM-MBX-T4-5GK 4x 5G North America 5G (NSA & SA) Sub 6Ghz:
Product Code Description ACW-630 Includes 1x 54V, 3.34A Power Supply Enable 4x LAN with 802.3at PoE output (PoE License automatically applied after kit purchase)
ACW-633 Includes 2x 54V, 3.34A Power Supply Enable 4x LAN with 802.3at PoE output (PoE License automatically applied after kit purchase)
ACW-674 1x 54V/5.56A 300W Power Supply Unit ACW-675 1x 54V/7.41A 400W Power Supply Unit SIM-BK8-4E-56V SIM Injector, 8x SIM cards capacity, 4x 10/100/1000 LAN ports, 56V DC MAX-HD-020-SPF Enable up to 20 SpeedFusion VPN Peers SFN-LC-50 Enable up to 50 SpeedFusion VPN Peers ECP-MAX-HD2-MBX-LTEA-RK-1Y EssentialCare+ (1-Year) for MAX HD2 MBX LTEA (CAT-12) ECP-MAX-HD2-MBX-LTEA-RK-2Y EssentialCare+ (2-Year) for MAX HD2 MBX LTEA (CAT-12) ECP-MAX-HD2-MBX-LTEA-RK-4Y EssentialCare+ (4-Year) for MAX HD2 MBX LTEA (CAT-12) SVL-MAX-HD2-MBX-LTEA-RK-1Y 1-Year EssentialCare for MAX HD2 MBX LTEA (CAT-12) SVL-MAX-HD2-MBX-LTEA-RK-2Y 2-Year EssentialCare for MAX HD2 MBX LTEA (CAT-12) ECP-MAX-HD2-MBX-5G-1Y EssentialCare+ (1-Year) for MAX HD2 MBX (5G) ECP-MAX-HD2-MBX-5G-2Y EssentialCare+ (2-Year) for MAX HD2 MBX (5G) ECP-MAX-HD2-MBX-5G-4Y EssentialCare+ (4-Year) for MAX HD2 MBX (5G) SVL-MAX-HD2-MBX-5G-1Y 1-Year EssentialCare for MAX HD2 MBX (5G) SVL-MAX-HD2-MBX-5G-2Y 2-Year EssentialCare for MAX HD2 MBX (5G) ECP-MAX-HD2-MBX-GLTE-G-1Y EssentialCare+ (1-Year) for MAX HD2 MBX (CAT 18) ECP-MAX-HD2-MBX-GLTE-G-2Y EssentialCare+ (2-Year) for MAX HD2 MBX (CAT 18) ECP-MAX-HD2-MBX-GLTE-G-4Y EssentialCare+ (4-Year) for MAX HD2 MBX (CAT 18) SVL-510 1-Year EssentialCare for MAX HD4 MBX LTEA (CAT-18) SVL-708 2-Year EssentialCare for MAX HD4 MBX LTEA (CAT-18) ECP-MAX-HD4-MBX-5G-1Y EssentialCare+ (1-Year) for MAX HD4 MBX 5G ECP-MAX-HD4-MBX-5G-2Y EssentialCare+ (2-Year) for MAX HD4 MBX 5G ECP-MAX-HD4-MBX-5G-4Y EssentialCare+ (4-Year) for MAX HD4 MBX 5G SVL-MAX-HD4-MBX-5G-1Y 1-Year EssentialCare for MAX HD4 MBX (5G) SVL-MAX-HD4-MBX-5G-2Y 2-Year EssentialCare for MAX HD4 MBX (5G) LIC-VWAN Activate 1x Virtual WAN LIC-2VWAN Activate 2x Virtual WAN LIC-3VWAN Activate 3x Virtual WAN -
MAX HD2 MBX (CAT-20)
- MAX HD2 MBX
- 1x PSU 180W (ACW-630)
- 4x Wi-Fi Dual Band Antenna (ACW-341)
- 1x GPS Antenna (ACW-232)
- 8x LTE/5G Antennas (ACW-234)
- 1 Pair of Mounting Brackets (ACW-513)
- 3pin Terminal Block Connector (Ignition sense)
- 4pin Terminal Block Connector (Power supply)
- Grounding cable
- Rubber Foot Pad set
MAX HD2 MBX 5G
- MAX HD2 MBX
- 8x LTE/5G Antennas (ACW-235)
- Grounding cable
MAX HD4 MBX (CAT-12)
- MAX HD4 MBX
- Grounding cable
MAX HD4 MBX (CAT-20)
- MAX HD4 MBX
- 1x QMA to SMA Adaptor (for GPS)
- Grounding cable
* Cellular antennas not included. To enhance the MBX, Mobility and Maritime antennas are recommended.
MAX HD4 MBX 5G
- MAX HD4 MBX
- Grounding cable
Product Code Description ANT-MB-42G-S-W-6 7-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White) ANT-MB-42G-S-B-6 7-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black) ANT-MB-40G-S-W-6 5-in-1 Cellular Antenna System with GPS Receiver (White) ANT-MB-40G-S-B-6 5-in-1 Cellular Antenna System with GPS Receiver (Black) ANT-MB-02-R-W-6 2×2 MIMO Wi-Fi Dual Band Antenna (White) ANT-MB-02-R-B-6 2×2 MIMO Wi-Fi Dual Band Antenna (Black) ANT-MB-42G-Q-W-6 7-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White / QMA) ANT-MB-40G-Q-W-6 5-in-1 Cellular Antenna System with GPS Receiver (White / QMA) ANT-MB-40G-Q-B-6 5-in-1 Cellular Antenna System with GPS Receiver (Black / QMA) ANT-MB-82G-S-W-6 11-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White/ SMA) ANT-MB-82G-Q-W-6 11-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White/ QMA) Antenna Guide
Click the images below to Learn More
MAX HD2/HD4 MBX Datasheet
MAX MBX ESN Datasheet
MAX MBX 5G Datasheet
Module Upgrade Installation Guide
User ManualCase Studies
- A Moving Workplace
- LVHN Dorney Vaccine Drive-Through Clinic
- Tutoring Camp Project
- Connecting a Drillship to Her Headquarter Using LTE
- Rapidly Deploy Reliable Communications for Healthcare in Trying Times
- The U.S. Ski and Snowboard Team Stays Connected
- LTE SD-WAN for the Oil & Gas Industry
- Constant Connectivity for Code Blue Help Points
