Use Cases
Maritime
Constructions & Utilities
Public Safety & First Responders
Compatible With:
Dual Cellular for Multiple Carriers
The HD2 IP67 includes two built-in outdoor 4G LTE/3G modems. It allows you to use the same or different cellular providers for bandwidth bonding or eliminating blind spots.
Optional PoE Input
Cut down on cabling and simplify deployments. The HD2 IP67 supports 802.3at PoE+ input, so one wire is all you need for both connectivity and power. 802at PoE+ Injector is available separately.
Super-Duty IP67 Enclosure
The HD2 IP67 outdoor router has a waterproof IP67 metal enclosure that stands up to dust, vibration, and inclement weather.
Certified Toughness
MAX HD2 IP67 is shock and vibration resistant, making it a great choice for construction, drilling, and other heavy-duty applications.
Shock and vibration resistance
EN 61373:2010 IEC 61373:2010
RF Port Lightning Immunity
(ITU-T K.20 (+/- 1.5 kV))
FCC, CE, RoHS, IC
FirstNet Ready
FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The MAX HD2 IP67 supports band 14, providing additional coverage as the situation demands.
#PowerofPeplink
