Compare Router models
Quick Look
No differences
Number of Ethernet WAN port
0 / 1 (GE) 1
2 / 1 (2.5G) 2
2 (GE)
Number of Ethernet LAN port
3 / 2 (GE) 1
4 / 5 (GE) 2
4 (GE)
Router Throughput
300Mbps
Router Throughput
1Gbps
Router Throughput
1Gbps
80Mbps
400Mbps
400Mbps
60Mbps 3
200Mbps
200Mbps
Number of Cellular Modem
1
2
1
Interfaces
No differences
1 WAN with 2 LAN
0 WAN with 3 LAN
2 WAN with 4 LAN
1 WAN with 5 LAN
2 WAN with 4 LAN
SFP LAN / WAN
No
SFP LAN / WAN
No
SFP LAN / WAN
No
Serial Interface
No
Serial Interface
Yes (RS232)
Serial Interface
No
Wi-Fi AP
Yes
Wi-Fi AP
Yes
Wi-Fi AP
Yes
Wi-Fi WAN
Yes 1
Wi-Fi WAN
Yes
Wi-Fi WAN
Yes
USB WAN
No
USB WAN
Yes (1x USB)
USB WAN
Yes (1x USB-C)
Module Expansion
No
Module Expansion
No
Module Expansion
No
Performance
No differences
Number of Recommended Users
1–60
1–150
1–150
Maximum Number of AP Supported
No
30 / 50 4
30 / 50 4
Wireless details
No differences
1x 5G
2x 5G
1x 5G
5G support
Yes
5G support
Yes
5G support
Yes
SIM Slots
2
SIM Slots
4
SIM Slots
2
SIM Card Size
Nano-SIM (4FF)
SIM Card Size
Nano-SIM (4FF)
SIM Card Size
Nano-SIM (4FF)
Wi-Fi Radio
Dual (2.4GHz + 5GHz) 5
2x2 Wi-Fi 5
Wi-Fi Radio
2x2 Wi-Fi 6
Wi-Fi Radio
2x2 Wi-Fi 6
20dBm
21dBm
20dBm
20dBm
22dBm
24dBm
Multiple SSIDs
16
Multiple SSIDs
16
Multiple SSIDs
16
GPS
No
GPS
Yes
GPS
No
Yes
Yes (HW2+)
Yes (HW2+)
FusionSIM
Yes
FusionSIM
Yes (HW2+)
FusionSIM
Yes (HW2+)
Peplink eSIM Data Plans
Yes
Yes 6
Yes
BYO eSIM
Yes
BYO eSIM
Yes 7
BYO eSIM
Yes
Features
No differences
SpeedFusion Hot Failover
Yes 1
Yes
Yes 8
SpeedFusion Smoothing
Yes 1
Yes
Yes 8
SpeedFusion Bandwidth Bonding
Yes 1
Yes
Yes 8
SpeedFusion Connect
Yes 9
SpeedFusion Connect
Yes 10
SpeedFusion Connect
Yes 11
Yes
Yes
Yes
Drop-In Mode
Yes
Drop-In Mode
Yes
Drop-In Mode
Yes
High Availability
Yes
High Availability
Yes
High Availability
Yes
Peplink AP Series Management
No
Yes
Yes
No
No
No
WAN as LAN
Yes
WAN as LAN
Yes
WAN as LAN
No
LAN Bypass
No
LAN Bypass
No
LAN Bypass
No
InTouch
Yes
InTouch
Yes
InTouch
Yes
Virtual WAN
Yes 12
Virtual WAN
Yes 12
Virtual WAN
Yes 12
Synergy Mode (Controller)
Yes
Yes
Yes
Synergized Device
Yes
Synergized Device
Yes
Synergized Device
Yes
Application and Web Blocking
Yes
Yes
Yes
Web Content Filtering
Lite
Lite
Lite
IP Passthrough
Yes
IP Passthrough
Yes 13
IP Passthrough
Yes
IPv6
No
IPv6
No
IPv6
No
x.509 Certificate
Yes 14
x.509 Certificate
Yes 14
x.509 Certificate
Yes 14
Captive Portal
Yes
Captive Portal
Yes
Captive Portal
Yes
GPIO
Yes
GPIO
Yes
GPIO
Yes
Ignition Sensing
Yes
Ignition Sensing
Yes
Ignition Sensing
No
Netflow support
Yes
Netflow support
Yes
Netflow support
Yes
LACP (802.3ad) NIC Bonding
No
Yes 15
No
No
Yes (8GB) 16
No
External Storage via USB Port
No
Yes 17
Yes 18
Dead Reckoning
No
Dead Reckoning
Yes
Dead Reckoning
No
Core Functionality
No differences
Inter-VLAN Routing
Yes
Inter-VLAN Routing
Yes
Inter-VLAN Routing
Yes
802.1q VLANs Supported
16
16
16
Port-Based VLAN
Yes
Port-Based VLAN
Yes
Port-Based VLAN
Yes
Load Balancing Algorithms
8
8
8
Load Balancing & Failover
Yes
Yes
Yes
Inbound Load Balancing
No
No
No
InControl 2 Cloud Management
Yes
Yes
Yes
No
Yes
No
Advanced QoS Functionality
No differences
Bandwidth Usage Monitoring
Yes
Yes
Yes
QoS for VoIP and E-Commerce
Yes
Yes
Yes
User Groups Bandwidth Control
Yes
Yes
Yes
VPN Functionality
No differences
SpeedFusion VPN
Yes
SpeedFusion VPN
Yes
SpeedFusion VPN
Yes
2 or 5 19
2 or 5 19
2 or 5 19
IPsec VPN
Yes
IPsec VPN
Yes
IPsec VPN
Yes
Number of IPsec Tunnels
5
5
5
Yes
Yes
Yes
3
3
3
No
No
No
5
5
5
5
5
5
Hardware
No differences
Enclosure
Compact
Indoor Metal
Enclosure
Indoor
Metal
Enclosure
Indoor
Plastic
Yes
Yes
Yes
No
No
No
AC Adapter or PSU
AC Input 100V–240V
DC Output 12V 2A
AC Adapter or PSU
AC Input 100V–240V
DC Output 12V
AC Adapter or PSU
AC Input 100V–240V
DC Output 12V 3A
Input voltage
DC 10–30V
Input voltage
DC 10–30V
Input voltage
DC 10–30V
PoE Input
Yes
PoE Input
Yes 20
PoE Input
No
PoE Output
No
PoE Output
No
PoE Output
No
USB Power Input
No
USB Power Input
No
USB Power Input
No
Nominal Power Consumption
13W
NA
7W
Maximum Power Consumption
18W
30W
19W 21
Dimensions in inches
4.95 x 4.2 x 1.4 inches
8.58 x 7.68 x 1.61 inches
10.31 x 6.33 x 1.31inch
Dimensions in mm
125.7 x 107 x 35 mm
Dimensions in mm
218 x 195 x 29.5 mm
Dimensions in mm
262 x 161 x 33.5mm
Weight (Pound)
0.93 pounds
Weight (Pound)
2.42 pounds
Weight (Pound)
1.7 pounds
Weight (Gram / Kilogram)
425 grams
1.1 kg
756 grams
Operating Temperature
-40°–149°F
-40°–65°C
-40°–149°F
-40°–65°C
-40°–113°F
-40°–45°C
Humidity
15%–95% (non-condensing)
Humidity
Humidity
10%–90% (non-condensing)
Rack-mount
No
Rack-mount
No
Rack-mount
No
Dual Hot Swap Power Supply
No
No
No
Warranty Info
No differences
Warranty
1-Year Limited Warranty
Warranty
Warranty
Browse
