Connect Everything Affordably
The BR1 PRO features 4x GE LAN ports to connect your wired clients, and 802.11 a/b/g/n Wi-Fi to connect your wireless clients. All this in rugged DIN mount compatible enclosure.
Fits Anywhere
At 5.1 x 4.3 x 1.6 inches, the BR1 Pro can fit into tight spaces. It can also be mounted on DIN rails from different angles, so it fits anywhere that the rails can be installed.
Mobile Ready
The BR1 Pro can accept power via a terminal block and is equipped with GPS. It also supports Ignition Sense, enabling it to power up or down depending on the vehicle’s ignition status.
Ignition Sense
Terminal Block
GPS
Primary Line with LTE Backup
In case of a WAN failure, SpeedFusion Hot Failover technology powers the MAX BR1 Pro for instant failover between wired and cellular links as needed to keep your connection stable and fast.
4-Port LAN Switch
The four-port GE LAN switch allows the BR1 Pro to be dropped into any network transparently, without needs for extra cabling. Perfect for Branch Networking.
Dual-Band Wi-Fi
The MAX BR1 Pro comes with embedded dual radio 802.11n Wi-Fi AP. It operates both in 2.4Ghz and 5GHz bands concurrently, reaching 300Mbps.
Redundant SIM Slots
Device utilizes redundant SIM slots with automatic switching for reliable network. You can also set the MAX BR1 PRO to automatically switch SIM cards when you’re in danger of exceeding a data cap. It also allows you to travel across borders without changing SIM cards manually.
Use Cases
In-Vehicle Deployments
Passenger Wi-Fi
LTE Backup for Branch Office
Topology
- The BR1 PRO provides 4-Port GE LAN switch and 11a Wi-Fi.
- In case of Landline, failure, SpeedFusion instantly and seamlessly switches traffic to 4G LTE backup; for always-on networking.
- Integrate easily with existing wireless networks. The BR1 PRO is compatible with wireless access points from Pepwave as well as third-party AP manufacturers.
There is More
We specialize in making complicated technologies simple. Achieve what others cannot with the following.
Fleet Tracking
Captive Portal
Hot Failover
Easy to Deploy
Fleet Tracking and Management
Track and manage your fleet from anywhere. With built-in GPS fleet tracking and InControl 2 cloud-based management, you can keep tabs on location and manage your mobile network from any Internet-connected device.
Customizable Captive Portal
Branding your captive portal is as easy as uploading your logo and terms & conditions. You can easily set bandwidth allowance and access duration per user or manage access using RADIUS server.
Setup a Social Wi-Fi Hotspot to receive valuable demographic data from your users.
Easy to Deploy
Set up the BR1 Pro without changing the network configuration of your other devices. Use InControl to manage your whole network from any web browser.
WAN Link Health Check
Bandwidth Allowance Monitor
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Security Stateful Firewall
DoS Prevention
Web Blocking
Complete VPN Solution SpeedFusion VPN/SpeedFusion
-Hot Failover
-Site-to-Site VPN
-Hot Failover
-256-bit AES Encryption
IPsec VPN (Network-to-Network)Advanced QoS Individual Bandwidth Limit
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoSGlobal Positioning System Integrated GPS
Device Location Map
Fleet Management with InControl 2Networking NAT and IP Forwarding
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
Captive Portal Support Support for Wired and Wireless LAN clients
Support RADIUS Authentication
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
Product Code Region | Carrier Embedded Modem 4G Bands 3G Bands MAX-BR1-PRO-LTEA-W-T Worldwide/
CAT-6
1 FDD LTE:
B1, B2, B3, B4, B5, B7, B8, B12, B13, B20, B25, B26, B29,
B30, B41
WCDMA/HSPA+/DC-HSPA+: B1, B5, B8
MAX-BR1-PRO-LTEA-P-T Asia Pacific/
CAT-6
1 4G LTE-A:
B1, B3, B5, B7, B8, B18, B19, B21, B28, B38, B39, B40, B41
B1, B5, B6, B8, B9, B19
TD-SCDMA: B39MAX-BR1-PRO-LTE-E-T Europe/
International/
CAT-4
1 4G LTE: B1, B3, B5, B7, B8, B20, B38 , B40, B41 WCDMA/HSPA+/DC-HSPA+: B1, B5, B8 -
Product Code Description MAX-BR1-ADV Advanced Feature Package includes a software license key for Advanced Car-Fi Roaming and SpeedFusion/IPSec X.509 Certification Support PVN-LC-05 Enables up to 5 SpeedFusion VPN / SpeedFusion peers MAX-LC-DIM Drop-in Mode for MAX BR1 Series ACW-DIN-M2MS DIN Rail mount kit that fits the BR1 M2M, BR1 Slim, BR1 Pro, SFE and UBR LTE. ECP-BR1-PRO-LTE-1Y EssentialCare+ (1-Year) for MAX BR1 Pro LTE ECP-BR1-PRO-LTE-2Y EssentialCare+ (2-Year) for MAX BR1 Pro LTE ECP-BR1-PRO-LTE-4Y EssentialCare+ (4-Year) for MAX BR1 Pro LTE SVL-777 1-Year EssentialCare for MAX BR1 Pro LTE SVL-677 2-Year EssentialCare for MAX BR1 Pro LTE ICS-012 1-Year InControl 2 Subscription ICS-024 2-Year InControl 2 Subscription ANT-MB-22G-S-W-6 5-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White) ANT-MB-22G-S-B-6 5-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black) PRM-B-1Y PrimeCare B (1-Year) for LTEA PRM-B-2Y PrimeCare B (2-Year) for LTEA PRM-B-4Y PrimeCare B (4-Year) for LTEA PCP-B-1Y PrimeCare+ B (1-Year) for LTEA PCP-B-2Y PrimeCare+ B (2-Year) for LTEA PCP-B-4Y PrimeCare+ B (4-Year) for LTEA -
- MAX BR1 Pro
- 12V2A Power Supply (ACW-632)
- 2x Wi-Fi Dual Band Antenna (ACW-341)
- 1x GPS Antenna (ACW-232)
- 2x LTE Antennas (ACW-813)
- 4pin Terminal Block Connector
- Rubber Foot Pad set
