Use Cases
Shock and vibration resistance
(EN 61373:2010)
Railway Applications
(EN 50155)
Electromagnetic Compatibility
(EN 61000)
FirstNet Ready
FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The MAX Transit supports band 14, providing additional coverage as the situation demands.
Simultaneous
Dual-Band 11ac Wi-Fi
Reduce Wi-Fi congestion and interference. Simultaneous dual-band Wi-Fi gives you two independent networks that also work together, maximizing the throughput that your passengers can enjoy.
Compatible With:
Compatible on all major carriers. Certified with Verizon* and T-Mobile.
*Not applicable to 5G SKU.
Install it Anywhere
With DIN rail mounts and mounting ears that can be installed from many angles, the MAX Transit is ready to fit into just about any space you have available.
Captive Portal
Fleet Tracking
Advertising Services
Wi-Fi Mesh
Integrated Captive Portal with Social Wi-Fi
The MAX Transit comes with a customizable captive portal what allows passengers to login with Facebook. As they login, you can use InControl 2 to see insightful reports on user demographics.
Fleet Tracking and Management
With built-in GPS fleet tracking and InControl 2 cloud-based management, you can keep tabs on location and manage your mobile network from any Internet-connected device. InControl 2 is our cloud based device management, monitoring, and reporting tool designed specifically for Peplink and Pepwave devices.
External Captive Portal for Advertising Servers
The MAX Transit also supports external captive portals, enabling you to connect to an advertising server. That way, your Wi-Fi hotspots can become a source of revenue.
Wi-Fi Mesh Support
Along with an AP Controller, this feature allows for a mesh extension to your network, which can expand network coverage and minimize dead zones.
WAN Link Health Check
Bandwidth Allowance Monitor
IPv6 SupportLAN DHCP Server for LAN Clients
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
-Weighted Balance
-Priority
-Overflow
-Persistence
-Least Used
-Lowest Latency
-Enforced
-Fastest Response Time
SpeedFusion
– Site-to-Site VPN
– SpeedFusion Hot Failover^
– SpeedFusion WAN Smoothing^
– SpeedFusion Bandwidth Bonding ^
– 256-bit AES Encryption
– Pre-shared Key Authentication
– Dynamic Routing
– PPTP VPN Server
– RADIUS, LDAP Authentication
IPsec VPN (Network-to-Network)@Networking NAT and IP Forwarding
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
Security 128-bit WEP
WPA & WPA 2
Stateful Firewall
DoS Prevention
Web Blocking
Application Prioritization
-SIP, HTTPS, VPN QoS
-Custom Application QoS
AP Controller AP Controller Support
Wi-Fi Usage StatisticsGlobal Positioning System Integrated GPS
Device Location Map
Captive Portal Support Support for Wired and Wireless LAN Clients
Support RADIUS Authentication
Social Wi-Fi Hotspot support
External Captive Portal supportCertifications -FCC, CE, RoHS, IC
-E-Mark*
-EN 61373:1999 IEC 61373:1999 Shock and Vibration Resistance
-EN 50155 Railway Applications – Electronic Equipment used on Rolling Stock
-EN 61000 Electromagnetic CompatibilityDevice Management Web Administrative Interface
Command Line Interface
InControl Cloud Management
Email Notification
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
^ Feature is available as an add-on license.* IPsec VPN supports connection with Cisco, Juniper, Peplink, or Pepwave devices.
@ X.509 is only supported on MAX-TST-DUO. -
Product Code Embedded
Modem(s)Regions LTE Bands 3G Bands MAX-TST-GLTE-G-T-PRM 1x CAT-18 Global / FirstNet B1, B3, B25(B2), B66(B4), B26(B5/B18/B19),
B7, B8, B12(17), B13,B14 , B20, B28, B29,
B30, B32, B71, B38, B39, B40, B41, B42,
B43, B46, B48B1, B2, B4, B5(B19), B8 MAX-TST-LTEA-R-T 1x CAT-12 America / FirstNet B1, B2, B3, B4, B5, B7, B8, B9, B12, B13, B14, B18,
B19, B20, B26, B29, B30, B32, B41, B42, B43, B46,
B48, B66HSPA+: B1, B2, B4, B5, B6, B8, B9, B19 MAX-TST-LTEA-K-T 1x CAT-12 Global B1, B2, B3, B4, B5, B7, B8, B9, B12, B13, B18, B19,
B20, B26, B28, B29, B30, B32, B41, B42, B43, B46,
B48, B66HSPA+: B1, B2, B4, B5, B6, B8, B9, B19 MAX-TST-LTEA-W-T 1x CAT-6 Worldwide B1, B2, B3, B4, B5, B7, B8 , B12, B13, B20, B25,
B26, B29, B30, B41WCDMA/HSPA+/DC-HSPA+: B1, B2, B3, B4, B5, B8 MAX-TST-LTEA-P-T 1x CAT-6 Asia Pacific B1, B3, B5, B7, B8, B18, B19, B21, B28, B38, B39,
B40, B41WCDMA/HSPA+/DC-HSPA+: B1, B5, B8, B9, B19
UMTS: B6 TD-SCDMA: B39MAX-TST-E-T 1x CAT-4 Europe / International B1, B3, B5, B7, B8, B20, B38 (TDD), B40(TDD),
B41 (TDD)WCDMA/HSPA+/DC-HSPA+: B1, B5, B8 * China & HK TD LTE are excluded.
Product Code Carrier Modem 5G Bands 4G Bands MAX-TST-5GD-T-PRM Global/5G 1 5G (NSA) Sub 6Ghz:
n1, n2, n3, n5, n7, n8, n12,
n20, n28, n38, n41, n66,
n71, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17,
B18, B19, B20, B25, B26, B28, B29, B30, B32,
B34, B38, B39, B40, B41, B42, B46, B48, B66, B71 -
Product Code
Description
PRM-MAX-TST-GLTE-G-1Y
1-Year PrimeCare for MAX Transit LTEA (CAT-18)
PRM-MAX-TST-GLTE-G-2Y
2-Year PrimeCare for MAX Transit LTEA (CAT-18)
PRM-MAX-TST-GLTE-G-4Y
4-Year PrimeCare for MAX Transit LTEA (CAT-18)
PRM-MAX-TST-5G-1Y
1-Year PrimeCare for MAX Transit 5G
PRM-MAX-TST-5G-2Y
2-Year PrimeCare for MAX Transit 5G
PRM-MAX-TST-5G-4Y
4-Year PrimeCare for MAX Transit 5G
ACW-DIN-TST
DIN Rail mount kit
ANT-MB-42G-S-W-6
7-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White) ANT-MB-42G-S-B-6
7-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black) ANT-MB-22G-S-W-6
5-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White) ANT-MB-22G-S-B-6
5-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black) PSC-210
1-Year SmartCare for MAX Transit LTEA PSC-410
3-Year SmartCare for MAX Transit LTEA SVL-424
1-Year EssentialCare for MAX Transit LTEA SVL-525
2-Year EssentialCare for MAX Transit LTEA FIPS-LC-TST
FIPS License for Transit PVN-LC-10
Up to 10 SpeedFusion VPN/ SpeedFusion Peers License Key for Selected Models MAX-HD-020-SPF
Up to 20 SpeedFusion Bonding License Key for MAX Series -
MAX Transit
- MAX Transit
- 12V2A Power Supply (ACW-601)
- 2x 5dBi Wi-Fi Antennas (ACW-341)
- 1x GPS Active Antenna (ACW-232)
- 2x 2dBi 4G LTE Antennas (ACW-234)
- 1 Pair of Mounting Brackets (ACW-724)
- 6pin Terminal Block Connector
MAX Transit (CAT-18)
- MAX Transit (CAT-18)
- 4x 2dBi 4G LTE Antennas (ACW-234)
MAX Transit 5G
- MAX Transit 5G
- 12V2A Power Supply (ACW-601),
- 2x Wi-Fi Dual Band Antenna (ACW-341)
- 1x GPS Antenna (ACW-232)
- 4x LTE/5G Antennas (ACW-235)
