Future Proof Design
The SDX supports a FlexModule, enabling you to customize the router with your choice of ports, as well as instantly apply new technology as it will be released and available.
Peplink team will build additional FlexModules as new technologies such as 5G emerge. Simply insert the new FlexModule and the SDX will become 5G ready; no need to purchase a new router.
Modular System. Complete Flexibility
4x cellular WAN
Combine cellular links for wireless SD-WAN backup to the primary connection.
8x copper WAN/LAN
Connect PoE-enabled modems on the WAN, or connect PoE devices such as cameras, IP phones, and Wi-Fi APs on the LAN.
4x fiber WAN/LAN
Build an all-Fiber network by connecting Fiber WANs and LAN Switches.
Enterprise Ready
Even without a FlexModule, the SDX is already prepared for any enterprise branch deployment. It comes equipped with 2x Ethernet WAN, 2x Gigabit Fiber WAN, and 2x USB WAN, enabling connectivity from multiple sources. The 8x integrated LAN ports can also power devices via PoE+.
FirstNet Ready
FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The HD4 MBX supports band 14, providing additional coverage as the situation demands.
Unbreakable Access to Cloud Applications
Whether via datacenter or Azure/AWS cloud, businesses now access their vital ERP, CRM, and POS applications online. To ensure absolute business continuity, the Balance SDX combines Ethernet and SFP+ WAN into an unbreakable SpeedFusion VPN.
End-to-End Fiber Network for Branch Offices
Insert a fiber FlexModule onto your SDX to create an all-fiber local network. Use the SDX’s built-in WAN ports to combine SFP+ and Ethernet links into a super-fast SpeedFusion VPN connection. Then use the fiber FlexModule to connect 4x 48-port fiber switches to the SDX. This creates a full fiber local network with optimimal connectivity between each client.
* WAN ports are configured as a LAN ports by default, configuration is changeable on the Web Admin.
8x GE PoE Module (EXM-8C) # Interface 8x 10/100/1000M Ethernet Ports *
Capable of PoE+Power Consumption 15W (255W max. with 802.3at/af PoE+ Output) Dimensions 4.1 x 7.4 x 1.5 inches
103 x 188 x 38 mmWeight 1.1 pounds | 475 grams
* Module can be configured with LAN or WAN ports as needed.
# Antenna is not included.
4x SFP+ Module (EXM-4F) # Interface 4x SFP+ Ports * Power Consumption 11W Dimensions 4.1 x 7.4 x 1.5 inches
103 x 188 x 38 mmWeight 0.83 pounds | 375 grams
3x LTE-A Module (EXM-3LTEA) # Interface 3x Embedded LTE-A Cellular Modems
with Redundant SIM Slots
Antenna Connectors 6x SMA Cellular Antenna Connectors
1x SMA GPS Antenna Connector
Downlink/Uplink Datarate 300Mbps/50Mbps (CAT-6)
600Mbps/150Mbps (CAT-12)
Power Consumption 20W Dimensions 4.1 x 7.4 x 1.5 inches
CAT-12. 4x LTE-A Module (EXM-4LTEA) # Interface 4x Embedded LTE-A Cellular Modems
with Redundant 4FF Mini SIM SlotsAntenna Connectors 8x SMA Cellular Antenna Connectors
1x SMA GPS Antenna ConnectorDownlink/Uplink Datarate 600Mbps/150Mbps Power Consumption 20W Dimensions 4.1 x 7.4 x 1.5 inches
CAT-18. 2x LTE-A Module (EXM-2GLTE-G) # Interface 2x Embedded LTE-A Cellular Modems
with Redundant 4FF Nano SIM SlotsAntenna Connectors 8x SMA Cellular Antenna Connectors
Downlink/Uplink Datarate 1.2Gbps/150Mbps Power Consumption 20W Dimensions 4.1 x 7.4 x 1.5 inches
2x 5G Module (EXM-2X5GD/EXM-2X5GH) # Interface 2x Embedded Cellular Modems
1x SMA GPS Antenna ConnectorDownlink/Uplink Datarate 5G: 4 Gbps / 700 Mbps
LTE CAT-20: 2 Gbps / 150 MbpsPower Consumption 20W Dimensions 4.1 x 7.4 x 1.5 inches
103 x 188 x 38 mmWeight 0.83 pounds | 375 grams # Antenna is not included.
Software Peplink Balance Firmware WAN Support for PPPoE, Static IP, DHCP
WAN Link Health Check
-PING
-DNS Lookup
-HTTP
Bandwidth Allowance Monitor
IPv6 Support
USB 4G/3G Modem Support
-changeip.com
-dyndns.org
-no-ip.org
-tzo.com
-DNS-O-Matic
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
-Weighted
-Enforced
-Persistence
-Priority
-Overflow
-Least Used
-Lowest Latency
-Fastest Response TimeSecurity DoS Prevention
Stateful Firewall
Web Blocking
Site-to-Site VPN
-Bandwidth Bonding
-Hot Failover
-256-bit AES Encryption
-Dynamic Routing
PPTP/L2TP/OpenVPN Server
-X.509 Certificate Support
-Bandwidth Reservation
-Individual Bandwidth Limit
Application Prioritization
-By User Groups
-SIP, HTTPS, VPN QoS
-Custom Application QoS
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
BGP, OSPFv2 and RIPv2 Support
Auto AP Discovery
Auto AP Firmware Management
AP Profile Configuration
Wi-Fi Usage Statistics
Support RADIUS Authentication
Support LDAP Authentication
DNS Built-in Authoritative DNS
Support for A, CNAME, NS, MX, PTR, SOA, SRV, TXT records
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
Power Requirements Universal Input 100V – 240V AC *Only valid for customers who have purchased Peplink Balance devices directly from Peplink.
Product Code Description ACW-748 Rack Mount Ears for Balance SDX ACW-752 Rack Mount Rails for Balance SDX SFN-LC-500 Enable up to 500 SpeedFusion Bonding peers for Balance SDX LIC-VWAN Activate 1x Virtual WAN on Balance SDX* LIC-2VWAN Activate 2x Virtual WAN on Balance SDX* LIC-3VWAN Activate 3x Virtual WAN on Balance SDX* ECP-BPL-SDX-1Y EssentialCare+ (1-Year) for Balance SDX ECP-BPL-SDX-2Y EssentialCare+ (2-Year) for Balance SDX ECP-BPL-SDX-4Y EssentialCare+ (4-Year) for Balance SDX SVL-494 1-Year EssentialCare for Balance SDX SVL-503 2-Year EssentialCare for Balance SDX * Learn more about Virtual WAN Activation License here.
Product Code Carrier Modem 4G Bands 3G Bands EXM-3LTEA-W America/Europe/
CAT-6
3 B1, B2, B3, B4, B5, B7, B8 , B12,
B13, B20, B25, B26, B29, B30, B41
B1, B2, B3, B4, B5, B8 EXM-3LTEA-P Asia Pacific/
CAT-6
3 B1, B3, B5, B7, B8, B18, B19,
B21, B28, B38, B39, B40, B41
B1, B5, B6, B8, B9, B19, B39 EXM-3LTEA-R America /
FirstNet /
CAT-12
3 B1, B2, B3, B4, B5, B7, B8, B9,
B12, B13, B14, B18, B19, B20,
B26, B29, B30, B32, B41, B42,
B43, B46, B48, B66
B1, B2, B4, B5, B6, B8, B9, B19 EXM-4LTEA-D APAC & EMEA /
CAT-124 B1, B2, B3, B4, B5, B7, B8, B9,
B12,B13, B14, B17, B18, B19,
B20, B21,B25, B26, B28, B29,
B30, B32, B38, B39, B40, B41,
B66HSPA+: B1, B2, B3, B4,
B5, B8, B9, B19EXM-4LTEA-R America /
FirstNet /
CAT-12
B43, B46, B48, B66
HSPA+: B1, B2, B4, B5, B6, B8, B9, B19 EXM-2GLTE-G Global /
CAT-18
2 B1, B3, B25(B2), B66(B4),
B26(B5/B18/B19), B7, B8,
B12(17), B13, B14 , B20, B28,
B29, B30, B32, B71, B38, B39,
B40, B41, B42, B43, B46, B48
B1, B2, B4, B5(B19), B8 Product Code Carrier Modems 5G Bands LTE Bands EXM-2X5GD Primary: APAC & EMEA
Compatible: Global2 5G (NSA) Sub 6Ghz:
n38, n41, n66, n71, n77, n78, n79B1, B2, B3, B4, B5, B7, B8, B12, B13,
B40, B41, B42, B46, B66, B71EXM-2X5GH Primary: North America
n1, n2, n3, n5, n28, n41, n66, n71,
B40, B41, B42, B46, B48, B66, B71 -
- Balance SDX
- SDX Base Chassis
- 1U 19″ Rack-mount Chassis (ACW-752)
- L-mount Set (ACW-748)
- 1x Power Cord (ACW-614)
- Rubber Foot Pad Set
- Balance SDX
Product Code Description BPL-SDX SDX Base Model, No Expansion module, 2x GE WAN Ports, 2x 10GbE SFP+ WAN ports, 8x GE LAN ports, 2x USB WAN Product Code Description EXM-8C Expansion Module with 8x GE PoE ports EXM-4F Expansion Module with 4x SFP+ ports EXM-4LTEA-D Expansion Module with 4x LTE-A Pro modems (CAT-12) EXM-4LTEA-R Expansion Module with 4x LTE-A Pro modems (CAT-12) EXM-2GLTE-G Expansion Module with 2x LTE-A Pro modems (CAT-18) EXM-2X5GD Expansion Module with 2x 5G modems EXM-2X5GH Expansion Module with 2x 5G modems EXM-2X5GN Expansion Module with 2x 5G modems -
SDX datasheet
FlexModule datasheetSDX Module upgrade guide
User ManualCase Studies
- School Connectivity
- Comwell Korsør
- Rapidly Deploy Reliable Communications for Healthcare in Trying Times
- MSP Creates a Stream of Reliable Connectivity for a Broadcasting Network
- Student Dormitories House Reliable Connectivity Through an MSP
- Reliable Communications for Healthcare
- A Marine Engineering and Construction Company Replaces Entire Network with SD-WAN Ecosystem
- Manufacturing Plant Assembles Complete Peplink Infrastructure for Reliable Connectivity
- Retail Financing Company Finds Gains in Peplink Network Upgrade
- BAOSN Goes Live with Full REMI using Peplink
- Peplink Steers Construction Vehicles Towards an Autonomous Future
- Do you have any suggestions for a 10G SFP transceiver?
Learn more about the recommended SFP transceiver at this post
