Scalable remote management for your local network. Simply plug in a USB dongle for out-of-band management.
Common Features
Remote Management
Out-Of-Band Management with a USB Dongle
Which one is right for you?
SD Switch 8-Port Rugged
PoE Enabled Switch with 8 Gigabit Ports & 2 SFP Ports for Industrial Environments. Ready for any Environment.
SD Switch 16-Port Rugged
PoE Enabled Switch with 16 Gigabit Ports & 2 SFP Ports for Industrial Environments. Ready for any Environment.
SD Switch 24-Port Rugged
PoE Enabled Switch with 24 Gigabit Ports & 2 SFP Ports for Industrial Environments. Ready for any Environment.
SD Switch 24-Port Enterprise
PoE Enabled Switch with 24 Gigabit Ports & 2 SFP Ports for Enterprise Deployment.
SD Switch 48-Port Enterprise
PoE Enabled Switch with 48 Gigabit Ports & 4 SFP Ports for Enterprise Deployment.
