8 Additional SIM With the SIM Injector
Use the SIM Injector to add another 8 SIM cards to your deployment, giving you the ability to connect to multiple carriers and ensuring that your connection remains unbreakable. The SIM Injector is capable of PoE output, so you don’t need to add another PoE switch to your deployment.
100 meter flexibility can be added with SIM Injector
In addition to adding SIM capacity, the SIM Injector also adds 100 meters of flexibility between the Router and the SIM cards, enabling you to place the cellular router anywhere you want without worrying about changing SIM cards.
SIM Injector uses a flexible architecture
You can connect multiple SIM Injectors to your device, and it will have access to all the SIM cards carried by the SIM Injectors.
Injector Overview
Specification Description SIM Slots 8x Active SIM Slots, Standard Size LAN Interface 4x GE, PoE 802.3at Support * Power Input DC Jack/Terminal Block: 12-56V Dimensions 1.6 x 5.8 x 5 inches | 40 x 147 x 128 mm Weight 430 grams | 0.94 pounds Operating Temperature -40° – 149°F | -40° – 65°C Humidity 15% – 95% (non-condensing) * 56V DC input is needed for 4x LAN ports to have 802.3at
Product Code Description SIM-BK8-4E-56V SIM Injector, 8x SIM cards capacity, 4x 10/100/1000 LAN ports, 56V DC -
- Power cable (ACW-614)
- Power supply (ACW-622)
^ Balance 20X, Balance 380X, and Balance 580X require FlexModule Mini for SIM Injector support, while SDX, SDX Pro, and EPX require a compatible FlexModule Plus.
* Please cross-check and confirm with the image below, the form factor of your FlexModule Plus.
Supported FlexModule Plus
Includes membrane marking ‘Cellular’
SIM slot size 4FF
Not Supported FlexModule Plus
Includes membrane marking ‘Main’
SIM slot size 2FF
