Quick Start Guide
SD Switch
1  Physical Setup of the Switch
›  Power On the Switch and connect to the internet
1 Unbox your Peplink switch and power the device. Once plugged in, the Power and Status Light will turn on.
Unbox your Peplink switch and connect it to power using the provided PSU adapter. Once plugged in, the Power and Status Light will turn on.
2 Connect your switch to your local network by plugging an Ethernet cable into one of the available LAN ports.
3 The IC2 light will turn green when the device is ready to be configured on inControl 2.
2  Registering the Switch on InControl2
›  Log In to Your InControl2 Account
4 Navigate to InControl2 and log in to your account, if you don’t have one yet, please create your account now.
InControl2
›  Add the Switch to InControl2
5 Navigate to the organization where you would like to assign the switch to. For new accounts, please create a new organization and group.
6 Under the Group Level, click Add Device.
Go to Devices then click Add Device.
7 Enter the Serial Number of your Peplink switch.
8 Once the device is added, it should appear under your Group Level’s device list in InControl 2.
Once the device is added, it should appear under your organization's device
You’re all set and ready to configure!
Configure the Switch from InControl2
›  Access the Switch’s Settings
1 From your device group, click “Edit”.
2 Check the box next to the switch and click “Actions” to change the device’s settings (updating Firmware, DHCP snooping, setting STP bridge priority etc).
                    settings
3 For more settings, click on the name of the device to open the device details.
4 Click Show Port List and then Edit.
                    settings
5 You can now apply various configurations remotely, including:
VLAN Setup: Create VLANs and assign different ports to different VLANs as needed.
Port Management: Control port settings such as speed control, port type, PoE (Power over Ethernet), RSTP and link aggregation.
Monitor and Control the Switch
›  Monitor Device Health
Use the Dashboard in InControl2 to monitor the switch’s performance metrics, including port utilization, traffic statistics, and system health.
Use the Dashboard in InControl2 to monitor the switch's performance metrics,
›  Access Remote Web Admin
InControl2 also provides direct access to the switch’s web admin interface remotely. We recommend configuring the switch over the inControl 2 as local web admin settings are limited.
                    remotely.
1 YEAR WARRANTY INCLUDED
to register: access.peplink.com
USER MANUALS*
peplink.com/manual
DEVICE MANAGEMENT
incontrol2.peplink.com
CERFIFIED PARTNERS
peplink.com/partners
MOBILE APP
peplink.com/mypeplink
PEPLINK COMMUNITY
forum.peplink.com
WARRANTY POLICY
peplink.com/warranty
*For access to certification regulations and Directive 2014/53/EU requirements, please download the corresponding user manual for your device.
