HD2/ HD4 MBX
Multi-Cellular Gigabit LTE Mobile Powerhouse
The HD2/ HD4 MBX is capable of combining the bandwidth of 2 or 4 cellular links into an unbreakable, high-speed SD-WAN connection. The HD4 MBX supports up to 8 SIM cards, with room for another 8 with the optional SIM Injector. With up to 16 cellular providers to connect to, spotty coverage will simply not be a problem.
Ready for Any Environment
Fanless Design
Thrives in high-particle environments that would break other fan-based routers.
8×802.3at PoE Outputs
Power your IP phones, cameras, and access points.
Robust Metal Enclosure
Same dimensions as the previous HD4, so it can fit seamlessly into any of your previous deployments.
Compatible With:
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #10
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #3
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #5
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #8
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #4
  • 2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #9
Compatible on all major carriers. Certified with Verizon* and T-Mobile.
*Not applicable to MAX-HD2-MBX-5GH-T. Verizon Certification is in progress.
Ideal for On-The-Go Deployments
Ignition Sensing gives it the ability to turn on and off depending on whether the vehicle has started. Upon vehicle shutdown, the MBX can also shut down after a user-defined interval, saving the battery from excessive drain.
The HD4 MBX also supports the optional SIM Injector, which adds another 8 cellular providers to connect with. This mitigates weak spots in cellular coverage, ensuring consistent connectivity . If your deployment crosses national boundaries, you can also use the SIM Injector to load multiple SIM cards, preventing roaming charges.
FirstNet Ready & ESN Certified
FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The HD4 MBX supports band 14, providing additional coverage as the situation demands.
Device has been also certified by UK’s Emergency Services Network (ESN).
Future Proof Design. Ready for 5G
Right out of the box, the HD4 MBX supports Gigabit LTE. For future technologies, the MBX features a swappable cellular module, so when you need to upgrade to 5G, you can simply swap your old one with a new one. The MBX is also capable of 2.5Gbps of throughput, giving you plenty of bandwidth for Gigabit Ethernet, 5G, or any future mobile technologies.
Pair with the 5G Ready Outdoor Antenna
The 5G ready Outdoor Antenna is suited to a wide range of outdoor public safety, mobile healthcare and even transportation deployments. It has support for extensive 5G global cellular frequencies including Band 71, ensuring enhanced reliability and coverage for any business-critical application.
Use Cases
The HD4 MBX Fits in a Variety of Scenarios
Live Streaming
Telemedicine
Branch Offices
Temporary Sites
Wi-Fi for Employees
Public Safety
2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #15
Event Live Streaming and Connectivity
The cellular SpeedFusion SD-WAN connection provides all the bandwidth you need to stream HD video. What’s more, our patented WAN Smoothing technology compensates for packet loss, ensuring smooth, jitter-free streaming.
2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #16
Telemedicine
Using SpeedFusion, the HD4 MBX can combine the bandwidth of 4x Gigabit LTE connections to form a fast and reliable VPN connection that can handle the requirements of remote diagnosis, that requires large amounts of data, more data than a single cellular link can transfer in a timely manner.
2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #17
Branch Offices
The HD4 MBX supports up to 8x 802.3at PoE connections, enabling you to connect your IP phones, IP cameras, and access points with minimal cabling. It also delivers 802.11ac Wi-Fi with a customizable captive portal for guest access. The HD4 MBX comes equipped with SpeedFusion WAN Smoothing, mitigating packet loss and ensuring that your videoconferences are jitter-free.
2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #18
Temporary Sites
By combining the bandwidth of up to 4x Gigabit LTE connections, you can perform fast and reliable connectivity no matter where the site is located. Quickly and safely transmit project data, emails, plans, and blueprints between personnel, sites, and headquarters.
2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #19
Wi-Fi on Employee Shuttles
Peplink ecosystem has all features that are needed for a successful employee bus deployments.  It combines the bandwidth of 4x Gigabit LTE connections on a packet level, ensuring employee productivity remains uninterrupted when cellular connections break. With HD4 MBX you can also simplify your cabling since it supports 802.3at PoE standard. Moreover you can also incorporate Smart Readers and TA system to your deployment this way controlling bus access and tracking employee usage.
2.5Gbps Quad Cellular Gigabit LTE Mobile PowerhouseMAX HD4 MBX #20
Public Safety
The HD4 MBX combines the bandwidth of 4x Gigabit LTE links into a fast, reliable, and secure SD-WAN connection, enabling you to stream high-definition video in real-time. This can all be achieved without investing in any infrastructure. With SpeedFusion-enabled devices on multiple vehicles and aerial resources, you can monitor the situation from multiple perspectives without needing a line-of-sight connection.
Experience on-demand connectivity with SpeedFusion Connect
Enabling the benefits of SpeedFusion has just gotten easier with SpeedFusion Connect. Allowing you to leverage the LTE of multiple connections and SpeedFusion technologies all under one subscription. Enabling backup connectivity has never been so simple!
*Compatible for use in the US and selected regions in Europe
Ports and Connections
  • WANSupport for PPPoE, Static IP, DHCP
    WAN Link Health Check
    PING
    IPv6 Support
    DNS Lookup
    HTTP
    Bandwidth Allowance Monitor
    USB 4G/3G Modem Support
    Intelligent Failover
    changeip.com
    dyndns.org
    no-ip.org
    tzo.com
    DNS-O-Matic
    Extended DHCP Option
    DHCP Reservation
    DNS Proxy for LAN Clients
    VLAN on LAN Support
    Per-Port VLAN Support
    Session Persistence
    Per-Service Load Distribution
    Multiple Algorithms
    Weighted
    Enforced
    Persistence
    Priority
    Overflow
    Least Used
    Lowest Latency
    Fastest Response Time
    Site-to-Site VPN
    Bandwidth Bonding
    Hot Failover
    256-bit AES Encryption
    Pre-shared Key Authentication
    Dynamic Routing
    PPTP VPN Server
    RADIUS, LDAP Authentication
    X.509 Certificate Support
    Advanced QoSUser Groups
    Bandwidth Reservation
    Individual Bandwidth Limit
    Application Prioritization
    By User Groups
    SIP, HTTPS, VPN QoS
    Custom Application QoS
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    WINS Server
    VRRP HA Support
    BGP, OSPFv2 and RIPv2 Support
    AP ControllerAuto AP Discovery
    Auto AP Firmware Management
    AP Profile Configuration
    Wi-Fi Usage Statistics
    SecurityDoS Prevention
    Stateful Firewall
    Web Blocking
    Web Filtering Blacklist
    Support RADIUS Authentication
    Command Line Interface
    InControl Cloud Management
    Email Notification
    Active Client & Session Lists
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
  • Product CodeCarrier
    Modems4G Bands3G Bands
    MAX-HD2-MBX-LTEA-R-TAmerica / FirstNet Ready /
    CAT-12
    2B1, B2, B3, B4, B5, B7, B8, B9, B12, B13,
    B14, B18, B19, B20, B26, B29, B30, B32,
    B41, B42, B43, B46, B48, B66
    B1, B2, B4, B5, B6, B8, B9, B19
    MAX-HD2-MBX-LTEA-D-TAPAC & EMEA / CAT-122B1, B2, B3, B4, B5, B7, B8, B9, B12, B13,
    B14, B17, B18, B19, B20, B21, B25, B26,
    B28, B29, B30, B32, B38, B39, B40, B41,
    B66
    MAX-HD2-MBX-LTEA-Q-TAPAC & EMEA / CAT-122B1, B2, B3, B4, B5, B7, B8, B12, B13,
    B28, B29, B30, B38, B39, B40, B41,
    B42, B43, B48, B66, B71
    B1, B2, B4, B5, B8, B9, B19
    MAX-HD4-MBX-LTEA-R-TAmerica / FirstNet Ready /
    CAT-12
    4B1, B2, B3, B4, B5, B7, B8, B9, B12, B13,
    MAX-HD4-MBX-LTEA-D-TAPAC & EMEA / CAT-124B1, B2, B3, B4, B5, B7, B8, B9, B12, B13,
    B66
    MAX-HD4-MBX-LTEA-Q-TAPAC & EMEA / CAT-124B1, B2, B3, B4, B5, B7, B8, B12, B13,
    MAX-HD2-MBX-GLTE-S-T
    Global /
    CAT-20
    2B1, B2, B3, B4, B5, B7, B8, B12, B13, B14,
    B30, B32, B34, B38, B39, B40, B41, B42,
    B46 (LAA), B48, B66, B71
    HSPA+/WCDMA: B1, B2, B3, B4,
    B5, B6, B8, B9, B19
    MAX-HD4-MBX-GLTE-S-TGlobal /
    FirstNet /
    CAT-20
    4B1, B2, B3, B4, B5, B7, B8, B12, B13, B14,
    B5, B6, B8, B9, B19
    MAX-HD2-MBX-ESN-GLTE-S-T
    Global / ESN
    CAT-20
    B5, B6, B8, B9, B19
    MAX-HD4-MBX-ESN-GLTE-S-TGlobal / ESN
    CAT-20
    B5, B6, B8, B9, B19
    * China & HK TD LTE are excluded.
  • Product CodeEmbedded modemsRegions5G BandsLTE Bands
    MAX-HD2-MBX-5GD-T2x 5GGlobal5G (NSA) Sub 6Ghz
    n1, n2, n3, n5, n7, n8, n12, n20,
    n28, n38, n41, n66, n71, n77, n78, n79
    B40, B41, B42, B46, B48, B66, B71
    MAX-HD2-MBX-5GN-T2x 5GGlobal
    5G (NSA & SA) Sub 6Ghz:
    n1, n2, n3, n5, n7, n8, n12, n13, n14,
    n18, n20, n25, n26, n28, n29, n30, n38,
    n40, n41, n48, n66, n70, n71, n75, n76,
    n77, n78, n79
    B40, B41, B42, B43, B46, B48, B66, B71
    MAX-HD4-MBX-5GD-T4x 5GGlobal5G (NSA) Sub 6Ghz
    MAX-HD4-MBX-5GN-T4x 5GGlobal^5G (NSA & SA) Sub 6Ghz:
    n77, n78, n79
    ^ US Carrier Certifications (MAX-HD4-MBX-5GN-T): AT&T, FirstNet, T-Mobile, Verizon (C-Band).
    EXM-MBX-T2-5GD2x 5GGlobal5G (NSA) Sub 6Ghz
    EXM-MBX-T2-5GH2x 5GGlobal5G (NSA) Sub 6Ghz
    n1, n2, n3, n5, n28, n41, n66, n71,
    n77, n78, n79
    EXM-MBX-T2-5GN2x 5GGlobal5G (NSA & SA) Sub 6Ghz:
    n77, n78, n79
    EXM-MBX-T4-5GD4x 5GGlobal5G (NSA) Sub 6Ghz
    EXM-MBX-T4-5GH4x 5GGlobal5G (NSA) Sub 6Ghz
    n77, n78, n79
    EXM-MBX-T4-5GN4x 5GGlobal5G (NSA & SA) Sub 6Ghz:
    n77, n78, n79
  • Product Code Description
    ACW-630 Includes 1x 54V, 3.34A Power Supply
    Enable 4x LAN with 802.3at PoE output (PoE License automatically applied after kit purchase)
    ACW-633 Includes 2x 54V, 3.34A Power Supply
    Enables 8x LAN with 802.3at PoE output (PoE License automatically applied after kit purchase)
    SIM-BK8-4E-56V SIM Injector, 8x SIM cards capacity, 4x 10/100/1000 LAN ports, 56V DC
    MAX-HD-020-SPF Enable up to 20 SpeedFusion VPN Peers
    SFN-LC-50 Enable up to 50 SpeedFusion VPN Peers
    ECP-MAX-HD2-MBX-LTEA-RK-1Y EssentialCare+ (1-Year) for MAX HD2 MBX LTEA (CAT-12)
    ECP-MAX-HD2-MBX-LTEA-RK-2Y EssentialCare+ (2-Year) for MAX HD2 MBX LTEA (CAT-12)
    ECP-MAX-HD2-MBX-LTEA-RK-4Y EssentialCare+ (4-Year) for MAX HD2 MBX LTEA (CAT-12)
    SVL-MAX-HD2-MBX-LTEA-RK-1Y 1-Year EssentialCare for MAX HD2 MBX LTEA (CAT-12)
    SVL-MAX-HD2-MBX-LTEA-RK-2Y 2-Year EssentialCare for MAX HD2 MBX LTEA (CAT-12)
    ECP-MAX-HD2-MBX-5G-1Y EssentialCare+ (1-Year) for MAX HD2 MBX (5G)
    ECP-MAX-HD2-MBX-5G-2Y EssentialCare+ (2-Year) for MAX HD2 MBX (5G)
    ECP-MAX-HD2-MBX-5G-4Y EssentialCare+ (4-Year) for MAX HD2 MBX (5G)
    SVL-MAX-HD2-MBX-5G-1Y 1-Year EssentialCare for MAX HD2 MBX (5G)
    SVL-MAX-HD2-MBX-5G-2Y 2-Year EssentialCare for MAX HD2 MBX (5G)
    ECP-MAX-HD2-MBX-GLTE-G-1Y EssentialCare+ (1-Year) for MAX HD2 MBX (CAT 18)
    ECP-MAX-HD2-MBX-GLTE-G-2Y EssentialCare+ (2-Year) for MAX HD2 MBX (CAT 18)
    ECP-MAX-HD2-MBX-GLTE-G-4Y EssentialCare+ (4-Year) for MAX HD2 MBX (CAT 18)
    SVL-510 1-Year EssentialCare for MAX HD4 MBX LTEA (CAT-18)
    SVL-708 2-Year EssentialCare for MAX HD4 MBX LTEA (CAT-18)
    ECP-MAX-HD4-MBX-5G-1Y EssentialCare+ (1-Year) for MAX HD4 MBX 5G
    ECP-MAX-HD4-MBX-5G-2Y EssentialCare+ (2-Year) for MAX HD4 MBX 5G
    ECP-MAX-HD4-MBX-5G-4Y EssentialCare+ (4-Year) for MAX HD4 MBX 5G
    SVL-MAX-HD4-MBX-5G-1Y 1-Year EssentialCare for MAX HD4 MBX (5G)
    SVL-MAX-HD4-MBX-5G-2Y 2-Year EssentialCare for MAX HD4 MBX (5G)
    LIC-VWAN Activate 1x Virtual WAN
    LIC-2VWAN Activate 2x Virtual WAN
    LIC-3VWAN Activate 3x Virtual WAN
  • MAX HD2 MBX (CAT-20)
    • MAX HD2 MBX
    • 1x PSU 180W (ACW-630)
    • 4x Wi-Fi Dual Band Antenna (ACW-341)
    • 1x GPS Antenna (ACW-232)
    • 8x LTE/5G Antennas (ACW-234)
    • 1 Pair of Mounting Brackets (ACW-513)
    • 3pin Terminal Block Connector (Ignition sense)
    • 4pin Terminal Block Connector (Power supply)
    • Grounding cable
    • Rubber Foot Pad set
    MAX HD2 MBX 5G
    • MAX HD2 MBX
    • 8x LTE/5G Antennas (ACW-235)
    • Grounding cable
    MAX HD4 MBX (CAT-12)
    • MAX HD4 MBX
    • Grounding cable
    MAX HD4 MBX (CAT-20)
    • MAX HD4 MBX
    • 1x QMA to SMA Adaptor (for GPS)
    • Grounding cable
    * Cellular antennas not included. To enhance the MBX, Mobility and Maritime antennas are recommended.
    MAX HD4 MBX 5G
    • MAX HD4 MBX
    • Grounding cable
  • Product CodeDescription
    ANT-MB-42G-S-W-67-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White)
    ANT-MB-42G-S-B-67-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (Black)
    ANT-MB-40G-S-W-65-in-1 Cellular Antenna System with GPS Receiver (White)
    ANT-MB-40G-S-B-65-in-1 Cellular Antenna System with GPS Receiver (Black)
    ANT-MB-02-R-W-62×2 MIMO Wi-Fi Dual Band Antenna (White)
    ANT-MB-02-R-B-62×2 MIMO Wi-Fi Dual Band Antenna (Black)
    ANT-MB-42G-Q-W-67-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White / QMA)
    ANT-MB-40G-Q-W-65-in-1 Cellular Antenna System with GPS Receiver (White / QMA)
    ANT-MB-40G-Q-B-65-in-1 Cellular Antenna System with GPS Receiver (Black / QMA)
    ANT-MB-82G-S-W-611-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White/ SMA)
    ANT-MB-82G-Q-W-611-in-1 Cellular and Wi-Fi Antenna System with GPS Receiver (White/ QMA)
    Antenna Guide
    Click the images below to Learn More
