SDX
Modular Enterprise Grade Router
As a member of our “X” series, the SDX offers extreme performance and future proof design at a practical price point. The SDX can handle the bandwidth requirements of any enterprise branch network. The SDX supports a FlexModule, enabling you to customize the router with your choice of ports, as well as instantly apply new technology as we release new modules.
Future Proof Design
The SDX supports a FlexModule, enabling you to customize the router with your choice of ports, as well as instantly apply new technology as it will be released and available.
Peplink team will build additional FlexModules as new technologies such as 5G emerge. Simply insert the new FlexModule and the SDX will become 5G ready; no need to purchase a new router.
Modular System. Complete Flexibility
4x cellular WAN
Combine cellular links for wireless SD-WAN backup to the primary connection.
8x copper WAN/LAN
Connect PoE-enabled modems on the WAN, or connect PoE devices such as cameras, IP phones, and Wi-Fi APs on the LAN.
4x fiber WAN/LAN
Build an all-Fiber network by connecting Fiber WANs and LAN Switches.
Enterprise Ready
Even without a FlexModule, the SDX is already prepared for any enterprise branch deployment. It comes equipped with 2x Ethernet WAN, 2x Gigabit Fiber WAN, and 2x USB WAN, enabling connectivity from multiple sources. The 8x integrated LAN ports can also power devices via PoE+.
FirstNet Ready
FirstNet (band 14) provides first responders with a specialized LTE network with more priority and network capacity. The HD4 MBX supports band 14, providing additional coverage as the situation demands.
Unbreakable Access to Cloud Applications
Whether via datacenter or Azure/AWS cloud, businesses now access their vital ERP, CRM, and POS applications online. To ensure absolute business continuity, the Balance SDX combines Ethernet and SFP+ WAN into an unbreakable SpeedFusion VPN.
End-to-End Fiber Network for Branch Offices
Insert a fiber FlexModule onto your SDX to create an all-fiber local network. Use the SDX’s built-in WAN ports to combine SFP+ and Ethernet links into a super-fast SpeedFusion VPN connection. Then use the fiber FlexModule to connect 4x 48-port fiber switches to the SDX. This creates a full fiber local network with optimimal connectivity between each client.
* WAN ports are configured as a LAN ports by default, configuration is changeable on the Web Admin.
  • 8x GE PoE Module (EXM-8C) ^
    Interface8x 10/100/1000M Ethernet Ports *
    Capable of PoE+
    Power Consumption15W (255W max. with 802.3at/af PoE+ Output)
    Dimensions4.1 x 7.4 x 1.5 inches
    103 x 188 x 38 mm
    Weight1.1 pounds | 475 grams
    ^ The 8xGE PoE+ FlexModule(HW2) is compatible with SDX (HW4 or above)
    * Module can be configured with LAN or WAN ports as needed.
    4x SFP+ Module (EXM-4F) #
    Interface4x SFP+ Ports *
    Power Consumption11W
    103 x 188 x 38 mm
    Weight0.83 pounds | 375 grams
    # Antenna is not included.
    3x LTE-A Module (EXM-3LTEA) #
    Interface3x Embedded LTE-A Cellular Modems
    with Redundant SIM Slots
    Antenna Connectors6x SMA Cellular Antenna Connectors
    1x SMA GPS Antenna Connector
    Downlink/Uplink Datarate300Mbps/50Mbps (CAT-6)
    600Mbps/150Mbps (CAT-12)
    Power Consumption20W
    103 x 188 x 38 mm
    CAT-12. 4x LTE-A Module (EXM-4LTEA) #
    Interface4x Embedded LTE-A Cellular Modems
    with Redundant 4FF Nano SIM Slots
    Antenna Connectors8x SMA Cellular Antenna Connectors
    Downlink/Uplink Datarate600Mbps/150Mbps
    103 x 188 x 38 mm
    CAT-20. 2x LTE-A Module (EXM-2GLTE) #
    Interface2x Embedded LTE-A Cellular Modems
    Downlink/Uplink Datarate2Gbps/211Mbps
    103 x 188 x 38 mm
    2x 5G Module (EXM-2X5G) #
    Interface2x Embedded Cellular Modems
    with Redundant 4FF nano SIM Slots
    Downlink/Uplink Datarate5G: 4 Gbps / 700 Mbps
    LTE CAT-20: 2 Gbps / 150 Mbps
    103 x 188 x 38 mm
  • SoftwarePeplink Balance Firmware
    WAN Link Health Check
    -PING
    -DNS Lookup
    -HTTP
    Bandwidth Allowance Monitor
    IPv6 Support
    USB 4G/3G Modem Support
    -changeip.com
    -dyndns.org
    -no-ip.org
    -tzo.com
    -DNS-O-Matic
    Extended DHCP Option
    DHCP Reservation
    DNS Proxy for LAN Clients
    VLAN on LAN Support
    Session Persistence
    Per-Service Load Distribution
    Multiple Algorithms
    -Weighted
    -Enforced
    -Persistence
    -Priority
    -Overflow
    -Least Used
    -Lowest Latency
    -Fastest Response Time
    SecurityDoS Prevention
    Stateful Firewall
    Web Blocking
    Site-to-Site VPN
    -Bandwidth Bonding
    -Hot Failover
    -256-bit AES Encryption
    -Dynamic Routing
    PPTP/L2TP/OpenVPN Server
    -X.509 Certificate Support
    Advanced QoS User Groups
    -Bandwidth Reservation
    -Individual Bandwidth Limit
    Application Prioritization
    -By User Groups
    -SIP, HTTPS, VPN QoS
    -Custom Application QoS
    Static Routes
    Port Forwarding
    Many to One, One to One NAT
    NAT Pool
    SIP ALG, H.323 ALG
    UPnP, NAT-PMP
    WINS Server
    BGP, OSPFv2 and RIPv2 Support
    Auto AP Discovery
    Auto AP Firmware Management
    AP Profile Configuration
    Wi-Fi Usage Statistics
    Support RADIUS Authentication
    Support LDAP Authentication
    DNSBuilt-in Authoritative DNS
    Support for A, CNAME, NS, MX, PTR, SOA, SRV, TXT records
    Command Line Interface
    InControl Cloud Management
    Email Notification
    Active Client & Session Lists
    Bandwidth Usage Statistics
    Syslog Service
    SNMP v1, v2c and v3
    Power RequirementsUniversal Input 100V – 240V AC
    *Only valid for customers who have purchased Peplink Balance devices directly from Peplink.
  • Product Code Description
    ACW-748 Rack Mount Ears for Balance SDX
    ACW-752 Rack Mount Rails for Balance SDX
    SFN-LC-500 Enable up to 500 SpeedFusion Bonding peers for Balance SDX
    LIC-VWAN  Activate 1x Virtual WAN on Balance SDX*
    LIC-2VWAN  Activate 2x Virtual WAN on Balance SDX*
    LIC-3VWAN  Activate 3x Virtual WAN on Balance SDX*
    ECP-BPL-SDX-1Y EssentialCare+ (1-Year) for Balance SDX
    ECP-BPL-SDX-2Y EssentialCare+ (2-Year) for Balance SDX
    ECP-BPL-SDX-4Y EssentialCare+ (4-Year) for Balance SDX
    SVL-494 1-Year EssentialCare for Balance SDX
    SVL-503 2-Year EssentialCare for Balance SDX
    * Learn more about Virtual WAN Activation License here.
  • Product CodeCarrierModem 4G Bands3G Bands
    EXM-3LTEA-WAmerica/Europe/
    CAT-6
    3B1, B2, B3, B4, B5, B7, B8 , B12,
    B13, B20, B25, B26, B29, B30, B41
    B1, B2, B3, B4, B5, B8
    EXM-3LTEA-PAsia Pacific/
    CAT-6
    3B1, B3, B5, B7, B8, B18, B19,
    B21, B28, B38, B39, B40, B41
    B1, B5, B6, B8, B9, B19, B39
    EXM-3LTEA-RAmerica /
    FirstNet /
    CAT-12
    3B1, B2, B3, B4, B5, B7, B8, B9,
    B12, B13, B14, B18, B19, B20,
    B26, B29, B30, B32, B41, B42,
    B43, B46, B48, B66
    B1, B2, B4, B5, B6, B8, B9, B19
    EXM-4LTEA-DAPAC & EMEA /
    CAT-12
    4B1, B2, B3, B4, B5, B7, B8, B9,
    B12,B13, B14, B17, B18, B19,
    B20, B21,B25, B26, B28, B29,
    B30, B32, B38, B39, B40, B41,
    B66
    B1, B2, B3, B4,
    B5, B8, B9, B19
    EXM-4LTEA-RAmerica /
    FirstNet /
    CAT-12
    B43, B46, B48, B66
    EXM-4LTEA-QAPAC & EMEA /
    CAT-12
    4B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B38, B39, B40, B41, B42, B43, B48, B66, B71B1, B2, B4, B5, B6, B8, B9, B19
    EXM-2GLTE-GGlobal /
    CAT-18
    2B1, B3, B25(B2), B66(B4),
    B26(B5/B18/B19), B7, B8,
    B12(17), B13, B14 , B20, B28,
    B29, B30, B32, B71, B38, B39,
    B40, B41, B42, B43, B46, B48
    B1, B2, B4, B5(B19), B8
    EXM-2GLTE-SGlobal /
    CAT-20
    2B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B46, B48, B66, B71B1, B2, B4, B5, B6, B8, B9, B19
    Product CodeCarrierModems5G BandsLTE Bands
    EXM-2X5GDAPAC & EMEA
    5G
    25G (NSA) Sub 6Ghz:
    n38, n41, n66, n71, n77, n78, n79
    B40, B41, B42, B46, B66, B71
    EXM-2X5GHNorth America
    5G
    25G (NSA) Sub 6Ghz:
    n1, n2, n3, n5, n28, n41, n66, n71,
    n77, n78, n79
    EXM-2X5GNAPAC & EMEA
    5G
    25G (SA&NSA) Sub 6Ghz:
    n1, n2, n3, n5, n7, n8, n12, n13, n14, n18, n20, n25, n26, n28, n29, n30, n38, n40, n41, n48, n66, n70, n71, n75, n76, n77, n78, n79
    B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B43, B46, B48, B66, B71
    • Balance SDX
      • SDX Base Chassis
      • 1U 19″ Rack-mount Chassis (ACW-752)
      • L-mount Set (ACW-748)
      • 1x Power Cord (ACW-614)
      • Rubber Foot Pad Set
  • Product CodeDescription
    BPL-SDXSDX Base Model, No Expansion module, 2x GE WAN Ports, 2x 10GbE SFP+ WAN ports, 8x GE LAN ports, 2x USB WAN
    EXM-8CExpansion Module with 8x GE PoE ports
    EXM-4FExpansion Module with 4x SFP+ ports
    EXM-SIM-BK56Expansion Module with 56 SIM slots
    EXM-4LTEA-DExpansion Module with 4x LTE-A Pro modems (CAT-12)
    EXM-4LTEA-RExpansion Module with 4x LTE-A Pro modems (CAT-12)
    EXM-4LTEA-QExpansion Module with 4x LTE-A Pro modems (CAT-12)
    EXM-2GLTE-SExpansion Module with 2x LTE-A Pro modems (CAT-20)
    EXM-2X5GDExpansion Module with 2x 5G modems
    EXM-2X5GHExpansion Module with 2x 5G modems
    EXM-2X5GNExpansion Module with 2x 5G modems
    • Do you have any suggestions for a 10G SFP transceiver?
      Learn more about the recommended SFP transceiver at this post
