Introducing Peplink
Firmware
8.4.0
Firmware 8.4.0 has arrived with many highly requested features from our community. Ranging from eSIMs to Starlink to Edge Computing, there’s bound to be something that’ll make your life just a bit easier.
Bring Your
Own eSIM
eSIM
Use your own eSIM to connect your Peplink device to the internet. With more and more carriers supporting eSIM plans, now you can bring them directly to your network. No more fumbling about with manually slotting in SIM cards.
Supercharged Starlink Integration
Starlink
USB Support
for Edge
Computing
USB
USB Support for Edge Computing
Load up dockers on a USB and run them directly on your Peplink device. Backing up and transferring dockers across devices is now as easy as that.
USB support for Edge Computing
USB supprt for edge computing
Features for Enterprise Users
Enterprise
Highly Requested Features
# VLAN on LACP
# NetFlow enhancements
# VLAN PPPoE support
We listen to our customers no matter how niche your requirements are. If there’s any other features you’d like to see, drop by our forums and start the conversation.
More QoS User Groups
We’ve increased the number of QoS user groups from 3 to 10. Customize your network traffic for even more efficiency.
More QoS user groups
PrimeCare Update
Certain models will now retain SpeedFusion functionality even after its PrimeCare subscription has expired.
PimeCare update
More application support
More Application Support for SFC Protect
SFC Protect now supports FaceTime, Google Meet, and Zscaler.
SFC Relay control
SFC Relay Access Control
Making frequent use of your SFC Relay? Now you can control which connections are able to access your network.
Addiotional QOL features
Feature Improvement
  • Renew FusionHub licenses from InControl
  • PoE now available on MBX Mini WAN Port
AP & SW FW update
AP & SW FW Update
Firmware for our Access Points(3.9.3) and SD Switches(1.3.1) have been updated as well. InTouch is now usable with our APs and Switches.
VLAN on LACP VLAN on LACP ×
NetFlow enhancements NetFlow enhancements ×
VLAN PPPoE support VLAN PPPoE support ×
SFC Relay Access Control SFC Relay Access Control ×
