We understand the importance of staying connected wherever you are. Whether you’re zooming around town or stationed in the middle of nowhere, roaming from network to network should not equate to downtime and more downtime. Which is why we believe in equipping our customers with best-in-class cellular routers to battle spotty coverage. Comprehensive 3G/4G LTE USB modem support. Embedded SIM slots. Wi-Fi-powered WANs.
Wherever you go, whatever you do, our MAX Cellular Routers have you covered.
Speed & Reliability. Over Any Connection.
Of course, none of that means squat if your mission-critical connections disconnect when transitioning from one link to the next. So we go the extra mile and insist that our customers are protected by packet-level seamless failover and bandwidth bonding across all cellular connections.
No more re-establishing connections. No more skipped video frames. And no more waiting on file transfers. Simply put, your connection is unbreakable.
High-Bandwidth Remote Connections
With MAX cellular routers, you can stream video and quickly transfer large files in remote areas with poor connectivity. SpeedFusion technology makes this possible by bonding the bandwidth of multiple cellular services. In addition to 3G/4G LTE connections, you can also add VSAT and land lines into your SpeedFusion tunnel.
Remote Office
Combine the bandwidth of up to 4 service providers for fast access to Head Office
Unbreakable VPN Powered by SpeedFusion
Add VSAT to further strengthen your connection
Head Office
Remote offices are able to access HQ resources as if they were on the same local network
Total Area Connectivity & Cloud Management
Combine the cellular reception of several service providers. If one provider should fail, others will take its place without any interruptions to your connections. InControl enables you to track the movements of your entire fleet on a single comprehensive screen.
Satisfied Customers
“Using Peplink routers, we bonded the signals from multiple embedded cellular devices to effect higher bandwidths. This allows us to send digital images from remote locations that typically have poor cellular coverage.”
Jerry McLarty, PhD Director of Cancer Prevention and Control, LSU Health Sciences Center
Case Study. MIT Robotics
MIT Robotics used two 4G LTE connections to build a VPN connection and instantly saw gains in bandwidth and reliability.
SpeedFusion technology ensured that connections load balanced and performed failover at the packet level. Should one connection go down, there would be no reconnection necessary and all sessions would remain persistent. As a bonus, the rover’s high bandwidth video stream could also split across both connections.
It’s Possible
Your vehicles will be able to travel across the city while passengers enjoy a continuous internet connection. Even from remote places, you will be able to stream large amounts of data, using SpeedFusion to bond several slower connections into a single fast connection.
Cellular is our business. Our industry-leading SpeedFusion technology is mature and widely used. And because we care, we continuously develop and innovate.
No matter what the situation, you can rest assured that you’re getting the best bandwidth bonding technology out there.
