Balance 2500 EC
エッジコンピューティングの頂点へ
エッジコンピューティングの最優選択肢
エッジコンピューティングは、データを本社に送信する前にローカルで処理することで速度を向上させます。1TBの内蔵ストレージを備えたBalance 2500 ECは、どんな負荷にも対応可能です。
ポートと接続
ギャラリー
概要
スペック
製品概要と比較表
詳細情報
SoftwarePeplink Balance Firmware
WAN Link Health Check
PING
DNS Lookup
HTTP
Bandwidth Allowance Monitor
IPv6 Support
USB 4G/3G Modem Support
changeip.com
dyndns.org
no-ip.org
tzo.com
DNS-O-Matic
Extended DHCP Option
DHCP Reservation
DNS Proxy for LAN Clients
VLAN on LAN Support
Session Persistence
Per-Service Load Distribution
Multiple Algorithms
-Weighted
-Enforced
-Persistence
-Priority
-Overflow
-Least Used
-Lowest Latency
SecurityDoS Prevention
Stateful Firewall
Web Blocking
Complete VPN SolutionSpeedFusion VPN/SpeedFusion Bandwidth Bonding
-Site-to-Site VPN
-Bandwidth Aggregation
-Hot Failover
-256-bit AES Encryption
-Dynamic Routing
-X.509 Certificate Support
PPTP/L2TP/OpenVPN Server
Advanced QoS User Groups
-Bandwidth Reservation
-Individual Bandwidth Limit
Application Prioritization
-By User Groups
-SIP, HTTPS, VPN QoS
-Custom Application QoS
Static Routes
Port Forwarding
Many to One, One to One NAT
NAT Pool
SIP ALG, H.323 ALG
UPnP, NAT-PMP
WINS Server
BGP, OSPFv2 and RIPv2 Support
Bonjour Forwarding
Auto AP Discovery
Auto AP Firmware Management
AP Profile Configuration
Wi-Fi Usage Statistics
Support RADIUS Authentication
Support LDAP Authentication
DNSBuilt-in Authoritative DNS
-Support for A, CNAME, NS, MX, PTR, SOA, SRV, TXT Records
Command Line Interface
InControl Cloud Management
Email Notification
Active Client & Session Lists
Bandwidth Usage Statistics
Syslog Service
SNMP v1, v2c and v3
Power RequirementsUniversal Input 100V – 240V AC
注文情報
Product CodeProduct NameDescription
BPL-2500-ECBalance 2500 ECEquipped with 4x 10G SFP+ ports, 16x (GE) Ethernet ports and 1TB SSD. SFP and Ethernet ports can be configured as WAN/LAN.
Supports Edge Computing. Capable of running Native App (Python), containers (Docker), and hypervisors (KVM).
注目の追加機能
製品コード
説明
SVL-730
1年版EssentialCare – Balance 2500 EC用
SVL-612
2年版EssentialCare – Balance 2500 EC用
ECP-BPL-2500-1Y
EssentialCare+ (1年) – Balance 2500用
ECP-BPL-2500-2Y
EssentialCare+ (2年) – Balance 2500用
ECP-BPL-2500-3Y
EssentialCare+ (3年) – Balance 2500用
LIC-VWAN 仮想WANの有効化: 1つ
LIC-2VWAN 仮想WANの有効化: 2つ
LIC-3VWAN 仮想WANの有効化: 3つ
パッケージ内容
  • 1x Balance 2500 EC
  • 2x 電源コード
  • 2x ラックユニットレール
  • マウントブラケット(1ペア)
データシート / リソース
お問い合わせ
当サイトをご訪問いただきありがとうございます!
